Halloween is basically built for the hacker. Besides the obvious fabrication of absurd costumes, there’s also the chance to showcase your skills, be they mechanical, audio, or video. It’s also a great time to show off our coolest tricks to inspire the young proto-hackers. If you need inspiration, we’ve got 150 ideas.
But this year will be different, I swear! I’m going to get it done early and test it out, with the luxury of time to debug the inevitable spiders. And you can swear too. Get started now on your Halloween project. Or at least next weekend.
What’s your favorite Halloween Hack?
Contests
If you need any more encouragement to fire up your black and orange hacking machine, think of Hackaday.io’s Halloween Hackfest. It runs until Oct 28, and all you have to do to enter is document your Halloween project on IO and press the “Submit” button. The deadline is the 28th, which still gives you a couple of nights to debug whatever didn’t work before the real deal. Prizes are shopping sprees at Digi-Key, and Adafruit is doubling the gift certificate if you use any Adafruit parts in the build.
If you don’t give a pumpkin about stupid ol’ Halloween, that’s cool too. (Grinch!) The 2021 Hackaday Prize has entered the final wildcard round. If your project didn’t fit in any of the previous categories, I’m pretty sure it’ll fit just fine in the anything-goes phase. Go nuts. We’d love to see what you’re working on.
I’s sure with a little editing Halloween can indeed be the day of the hacker.
https://phys.org/news/2021-09-mini-crispr-genome.html
Flourescent-protein pumpkins?
Did a radio controlled one a while back.
Scary voice, lighting, moving mouth etc using parts from a broken helicopter.
Unfortunately the LED got damaged because something came loose and put unregulated 3.3V directly into the diode despite the internal resistance of the battery and controller etc.
Makes note to add a fan and more importantly a proper series resistor.
