ATtiny-Powered Business Card Plays Cracktro Hits
Business Card-Tro
These cards plug into a USB port for power and have over a dozen small LEDs that light up the stars on the front, and a small buzzer that can play over ten minutes of cracktro music. To keep the cost down, [VCC] went with an ATtiny1616 microcontroller costing under 50 cents and still having plenty of outputs to drive the buzzer and LEDs. The final per-unit cost prior to shipping came out to only 1.5 euros, enabling them to be handed out without worrying about breaking the bank.
To aid in the assembly of the cards, [VCC] 3D printed a jig to apply material to the back of the USB connector, building up its thickness to securely fit in the USB port. He also wrote a small script for assembly-line programming the cards, getting the programming process down to around ten seconds per card and letting him turn through prepping the cards. Thanks, [VCC], for sending in your project—it’s a great addition to other PCB business cards we’ve featured.
11 thoughts on “ATtiny-Powered Business Card Plays Cracktro Hits
    1. The design shows clearly only two tracks (+ and -) are used, no data line – which make hacking impossible. The visible lack of power components makes “usb killer” impossible too.
      But next version will use an usb-c socket but a one side only assembly- it is chaperon than pcb usb and double side assembly.
    2. I guess ‘business people’ are too serious to have ever taken notice to a mains powered 5v power supply?
      Or a battery bank?
      That said, maybe this day and age its time to move on to USB-C.
      Also, a nitpick but, ‘cracktro music’? Thats a pretty tiny slit in the door, what about songs from Demos, or Keygens, or Musicdisks?
      This genre has a name, chiptunes.
Leave a Reply to huh?Cancel reply
