If you’re looking for a super cheap way to add LED lighting accents to your house, then this hack is for you! Corn-cob style LED light bulbs can be had for a few dollars. The bulbs include driver circuitry, and 8 LED arrays! All you have to do is take it apart.
[Martin Raynsford] stumbled upon this idea when trying to think of a way to light his laser engraving enclosure. It originally came with a regular light bulb, but it didn’t distribute light nicely and was in the way for some of his other planned upgrades.
Not wanting to add another DC power supply to the mix he remembered an old corn-cob LED light bulb he had — as it turns out, they’re pretty easy to take apart! Solder some longer leads on (take note of how they are wired, some are in series, some in parallel) and you’ve just made yourself some easy to use LED accent lighting!
Of course you could just buy those cheap LED rolls from China nowadays for next to nothing for your accent lighting.
[via Hacked Gadgets]
