This is a nice, compact gps logger that’s built around a PIC16F872 and some eeprom chips. It was designed for a particular GPS receiver, but should be easily adaptable to others since the unit ouputs standard sentences at 4800 baud. Full schematics and board layout are available on the project page.
14 thoughts on “Nano GPS Logger”
Leave a Reply to mikedCancel reply
as a big hackaday fan, I’m very surprised and happy to find out the nano logger I’ve done here :)
Note: it’s build around PIC16F876, not PIC16F872.
— Fabien
one more thing for the bat-belt :)
awesome DIY work. i have a general question, is it possible to make a gps update more than once per second?
i approve of this post.
Adam – To my knowledge 1 per second is standard. To get better time stamps you need to implement an RTK (real time kinetics) system.
Come on miked, we don’t need your approval or disapproval for every post. It’s getting a little old.
Hi,
This GPS is able to make a update every 1/5th second !
Fabien
I approve of the disapproval of people posting their approval or disapproval of posts.
End it already, the jokes gettin old.
Neat! Great work!
@adam
It would be possible to get up to 5hz using the EB-85A gpp reciever ( http://www.sparkfun.com/commerce/product_info.php?products_id=8266), although the GPS used for this tracker only supports 1 update per second. I haven’t looked at his code, but I believer that it would work ‘out of the box’ using the eb-85a gps and log 5 samples per second.
BTW, I am working on a gps logger than also transmits the location and some sensor data back to a base station for rocket tracking applications. http://krazerlasers.com/gps/
can this be used to track a subject by mounting under a car?
Here are 10Hz mini GPS modules available: http://www.perthold.de/index_p_en.htm (bottom of page). I got the module for 25 USD.
Maybe a Trackstick would do the trick.
Super-Duper site! I love it!! I believe I’m right to say GPS is more accurate than GSM tracking?
