DIY bench vice
diy_bench_vice
A bench vice can be one of the most used tools in your workshop.  For those that don’t have a workshop [Matt] built a vice that clamps to a table. He used scrap wood, MDF, threaded rod, washers, nuts, and wing nuts.  Cheap, easy to build, and very useful!
[via Toolmonger]
Comments
  1. amishx64 says:
    If that were my vice, it sure wouldn’t last long.
    Good for holding PCBs I guess though.
  2. Spadefinger says:
    lame
  3. zigzagjoe says:
    well, better than nothing, but not really good for much more than simple wood work. Not enough grip/rigidity
  4. roger_that says:
    I require more instruction from and instructable…
  5. JustGrumpyIguess says:
    @amishx64 I guess if you work on your pcb in a vertical position…..
    Seems like adjustments more than half inch or so would be a pita considering the fine thread pitch.
    I would hardly call that an instructable.
    I guess in a pinch….. but i sure would’nt publish it.
  6. Don’t get me wrong I am very cheap, though seems like shelling out $20 for a cheap vice would be much easier and less frustrating in the long run. Especially the first time I turned without looking and smacked my hip into the wood if I was luck and threaded rods if not so lucky.
  7. amishx64 says:
    @JustGrumpyIguess:
    LOL Vertical PCB soldering? Not exactly.
  8. @amishx64 guess you haven’t taken the advanced soldering class :)
  9. chris says:
    Wow, this takes freetard to a new level of cheapness. Why didn’t you use wood from old pallets or better yet sticks off the ground?
    If you can’t afford a $12 vise I can wait to see how you drill holes!
  10. dumbdumb says:
    why not just hot glue some c clamps to your bench? probably stronger.
  11. dave says:
    Why not make a vise, instead? Aren’t there enough cheap vices for everyone these days, like…booze, or porn?
  12. Adam Ziegler says:
    @dave LOL!
  13. Matt byrne says:
    Wow, some harsh comments indeed !
    @amishx64 I’ve just added some more steps to the Instructable
    RE: all the cracks about cheapness, yes I can go and buy a nice new vice, but this just seemed like a fun little project, and if it didn’t perform well as a vice, I can just take it to bits – simple.
    And to be honest, I’m quite into the design process (albeit very basic in this example), and working out how to build things from scratch.
    Have a good one.
  14. Ben Jackson says:
    A “real” vise like that is too cheap to make a poor clone of. You can have one made of cast iron and a similar design for under $20.
    Making your own tooling is a valuable skill, but you’ve got to recognize where you’ll get the most bang for your buck.
  15. Daniel O.Apata says:
    please send me a write up project on bench vice. thanks
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
