[H. P. Friedrichs], the creator of the Static Bleeder has created his own diodes. Using household chemicals, a film of cuprous oxide was made on a copper pipe cap. Cuprous oxide has been one of the first known semiconductor substances, has a low forward drop but is an otherwise asymmetrical conductor, odd V-I curves, and some neat photovoltaic action. The apparatus seen above is used to bring a piece of lead (in this case, solder) into contact with the salmon-colored cuprous oxide while electrical connections can be made to the binding posts at the front. What are your thoughts on this device?
DIY Diodes
47 thoughts on “DIY Diodes”
Leave a Reply to yobyfedCancel reply
I think that is one of the coolest things I have ever seen…..
totally beautiful!! A work of art.
Kind of a transition from Steampunk to modern semiconductor electronics. I love all that copper and brass! Gonna fire up my Jacob’s ladder this weekend and whip up something.
Am I wrong for immediately picturing a second oxide pipe cap at the other end of the solder, creating a very crude transistor?
No that wont work. The base of the transistor has to be quite thin and be out of semiconductor itself. You would only make half bridge rectifier.
Absolutely beautiful!
I skimmed the article, but I didn’t see any information on the characteristics of the diode. I did a quick search and turned up the following.
Copper oxide has a knee of 0.2V, but the reverse breakdown voltage is around 5 Volts, so for many applications a series of diodes is used to increase the reverse breakdown (and as a side effect the knee voltage will be higher). The other drawbacks are metallic rectifiers are affected by temperature, atmospheric conditions (I guess could be fixed by different construction), and aging (e.g. resistance goes up over time).
Some basic information: http://en.wikipedia.org/wiki/Metal_rectifier and http://www.tpub.com/content/neets/14179/css/14179_38.htm
An in-depth article of properties: http://answers.google.com/answers/threadview/id/397640.html
His books are my favorite. Especially The Voice Of The Crystal: How To Build Working Radio Receiver Components Entirely From Scratch
Beautiful!
“Am I wrong for immediately picturing a second oxide pipe cap at the other end of the solder, creating a very crude transistor?”
That is the equivalent of connecting the anodes or cathods of two diodes – which AFAI remember doesn’t make a transistor. A transistor isn’t just two diodes – it is a sandwich of two pieces of bread with some semiconductor meat between them e.g. NPN has P-type semiconductor meat. When you put a voltage onto one PN junction it starts conducting and that changes the electrical properties of the P so that the other junction conducts too. That doesn’t happen with two open meat sandwiches (two diodes) with wire between the meat.
I am trying to think of a good car analogy using a freeway, an on-ramp, and an off-ramp with a road jam and charge carrier cars…
FAIL… it needs to be in a walnut box…
50 years ago we used an old razor blade and a pencil lead to make a diode and a crystal radio. see here http://sci-toys.com/scitoys/scitoys/radio/homemade_radio.html
I’m no rocket scientist, but that…thing, it is quite pretty.
Thanks for that link David. That’s a pretty sweet website.
I was just watching a video from MAKE about diodes that had a few of these in it. Its on youtube and titled Make Presents The Diode. Awesome work!
It’s called a cats whisker, and it’s been around since the days of crystal radio.
http://en.wikipedia.org/wiki/Cat%27s-whisker_detector
This is easily the awesomest thing I’ve seen this year.
I wish transistors were equally as simple to pull off.
I wonder if he’s thought of using silicon carbide (carborundum) crystals? It has pretty good diode characteristics, and can even make a blue LED!
(From http://en.wikipedia.org/wiki/Silicon_carbide):
Electronic applications of silicon carbide as light emitting diodes and detectors in early radios were first demonstrated around 1907, and nowadays SiC is widely used in high-temperature/high-voltage semiconductor electronics.
Oh, and @ Quin above; If he were to add another lead and poked around patiently, he might just be able to find two points on the surface that, along with the base connection, that act like a transistor.
Oleg Vladimirovich Losev just may have done just that in 1941, see here for details:
http://www.newscientist.com/blog/technology/2007/04/led-older-than-we-thought.html
And now that I’ve bored you all with forgotten history, I’ll go back to lurking.
I think “Cool!”
I just had a test on the fabrication and theory of operation of diodes!!
Thats awesome!
Look into foxhole radios. People have been making diodes since before WWII. All it takes is a single diode to receive AM radio.
SPLENDID!
Why with such a device we could one day send messages through the very aether with nary a wire to be seen!
This is *not* RoHS compliant.
Like GOOD solder.
Great desert island technique :D
where can i buy silicon carbide (carborundum) crystals?
Reminds me of the famous picture of The First Transistor.
two of these, facing opposite ways in parallel as the feedback loop of an opamp = awesome distortion pedal. Different diodes don’t always clip identically over all frequencies, Just like when you replace the back to back diodes in a tube screamer or almost any generic distortion pedal. you can replace them with different kinds of leds (you can really hear the difference) or half transistors. power diodes almost always sound better for example.
@robocat
I didn’t assume it would be that easy. It’s not my field, so I wasn’t sure whether the whole stick of solder would be too large to behave as the entire junction. I take it that it would be.
But still, picture the mythical steampunk inventor, who just built a transistor. Then the over sized op-amp, and TTL.
@rooftop ridicule
Replace diodes? The schematics for those pedals are all over the place. Build one from parts! I used to keep several on breadboards. Multiple diodes on one direction, or none, to change the top or bottom of the wave form. Different caps and resistors to change the frequency response of the amp.
Pair this with the SiC whisker LED (Make your own LEDs) that was on HAD a while back, and you could get some really weird distortion.
This looks a lot like the old apparatus for holding a galena crystal and the phosphor-broonze wire (“cats whisker”) that formed the detector diode in old crystal radios. We built one using fool’s gold instead of galena. See it here:
http://www.youtube.com/watch?v=p1h-Ro0qVfA
More info on crystal set adventures here:
http://soldersmoke.blogspot.com/search/label/crystal%20radio
Very steampunk. I like it :)
Beautiful.
A great design. Gotta love electrochemistry.
You are everything that is good and beautiful in the world sir.
One of my lecturers was reminicising last year about making a transistor as Quin thinks above, when proper transistors were extremely expensive. iirc they sort of worked but the biggest problem he had was parameter differences between the two diodes.
Really? In a real transistor the two “diodes” are quite different. The emitter is heavily doped for good current gain but so the BE diode has very low breakdown voltage (5 to 12V). For good breakdown voltage of the transistor the collector is much lighter doped.
home made:
diode
gunn diode
laser
FET transistor
flame triode
CRT
http://www.sparkbangbuzz.com/
Alright, so the lead solder wouldn’t work as the other junction. I did some digging, though, and found this http://www.aethmogen.com/wri/radams/tenigma1/07ada/01txt.shtml
A crystal transistor, built in the 1930s. Now to find some brass fittings . . .
this link is dead now does anyone have the info that was there please ???
point contact transistor from junck crystal is something of luck, bell labs get some results quickly but Japanese stick needles under microscope for couple months without results
Quite similar to this old precision cats whisker.
http://upload.wikimedia.org/wikipedia/commons/2/23/Precision_cat's_whisker_detector.jpg
@the moogle carborundum has been used for donkey’s years in seating new valves into the head when reconditioning and engine. not sure if it’s chemically similar though.
Great build, bravo!
I wonder how a couple of these diodes would sound if used to make a fuzz box, their curves should produce unique distortion.
does it come in smt?
Brilliant! I so want to build on of my own!
What about combining with hematite as resistor and cupperwound coil …. hmm …. what about an active semiconductor: a transistor. Come on, go ahead. Make a complete diy oscilator that way because you sure know how to also make a capacitor. Try as much bare material as possible for the coil and capacitor only relying on the shape of the material. Dielectric being air … or other natural material. No plastics since it MUST last at least thousands of years. Yes you heard me right :) => 10.000 BC and EMP proof.
Brilliant! I so want to build on of my own! Like!
