Touch-based wirless RGB lamp control
[Alex] built an add-on board for his TI launchpad that lets him use it as a wireless controller for an RGB lamp (translated). As you can see above, the board has a pair of female pin-headers which make it easy to install or remove the board. This way you can use it for other projects without any hassle.
The board itself doesn’t have any buttons. Instead, [Alex] etched a two-sided PCB, including pads for use as capacitive touch sensors. Here we only see the underside of the board, which hosts four RGB LED modules. These give feedback by showing the levels which are about to be set for each color. In the clip after the break you’ll get a good look at the touch sensors. There are two that act like buttons, scrolling through each color channel, and sending the updated values to the lamp via a wireless module mounted on that same side. There are also four pads which act as a slider. We didn’t see any code but apparently this uses one of TI’s touch sensor libraries.
Comments
  1. Alex says:
    Fix the title please.
  2. Hey, guys, thanks for featuring this project
  3. Hot User says:
    Hey, stallion!
  4. vonskippy says:
    Did the device buy you flowers after that stroke session?
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
