Android oscilloscope built from parts just lying around
So you need to debug a circuit and you don’t have an oscilloscope. That’s not a problem thanks to [retronics] $0 Android oscilloscope, made with parts he just happened to have lying around.
The heart of every modern oscilloscope is the ADC – the chip that takes analog input and outputs a digital signal. Every Android device has one of these converters connected to the microphone port. All [retronics] needed to do was solder up a 3mm headphone jack, wire in a few resistors, and attach a pair of alligator clips. After installing an oscilloscope app, [retronics] had a half decent ‘scope.
Yes, this is truly a poor man’s oscilloscope, and [retronics] probably won’t be debugging high frequency RF circuits with his Android microphone jack anytime soon. Low frequency stuff such as audio is where this ‘scope really excels; even more so if a small preamp is thrown into the mix.
You can check out [retronics]‘ build after the break. Sure, it’s not something for precise and calibrated measurement, but sometimes you only need a tool that will do the job.
Comments
  1. Paul Potter says:
    Simple, effective, and cheap. I like it.
  2. vcnbmxnm says:
    Apart from being on a phone, is this any different than a scope made from a PC and a soundcard?
    • Doctor says:
      A PC’s soundcard could handle higher sampling rates (around 192kS/s) with higher bit depths (around 24bit). But apart from that, I can’t think about other differences.
  3. Anonymous says:
    Cheap, until you blow up your phone and you have to buy a new one
    Remember that the mic input is probably 3.3v max
  4. Deedee says:
    A great idea , if something better is needed
    get a DSO201 on ebay for around 50$ with a 0-1Mhz
    bandwith very cheap but also very useable.
  5. Eric says:
    Off topic, but not really: parts don’t lay (transitive verb) unless they are the parts of a chicken laying an egg. They lie (intransitive verb). Correct title should be, “Android oscilloscope built from parts just lying around”.
    Sorry, but this always bugs me.
  6. Meez says:
    Very impressive, I hope cheap tech keeps spreading like this. It’s become trendy.
  7. gaigelama says:
    Eric, I reported your comment so they would read it.
  8. chris says:
    Yes but the microphone input is AC coupled, right ? That means it can’t work properly with DC applications ?
    • Eric says:
      Crap, accidentally reported (we really need a confirmation thingy for that)
      I just made one of these.
      Yes, the mic is AC coupled, DC does not work, and on my phone, if you do try to measure dc, it will bring up the music player.
      It does work reasonably well aside from that.
  9. mstone says:
    I applaud this for being a good hack, but something inside me cringes when I read “the heart of a scope is the ADC.”
    For reference, I’ve been reading a lot of old Tektronics service manuals lately.. things where they describe what’s involved in making a 100x probe that actually works, how to make high-bandwidth prescalers and buffers that don’t distort the signal, etc.
    I’ve also been reading a lot of Jim Williams (Tek once offered him a new scope for free — anything he wanted, no price limit, no questions asked — if he’d just stop using vintage units from the ’60s for all his tech notes.. he turned them down), and the combination of influences has rubbed off on me. I’m pretty sure I’ve become an analog oscilloscope snob.
    The heart of a scope is the signal path between the thing you want to measure and the display. In a sampling ‘scope, the ADC plays the role of the display. Once the signal goes digital, you’ve selected the information you want, and everything else is lost beyond recovery.
    The ADC is also at the mercy of the incoming signal path. It only measures what it sees in its sampling capacitor. It doesn’t know the first thing about any distortion that occurred between the DUT and its S/H input pin.
    So, again, kudos to the OP for a nifty hack, but getting output from the ADC is the last thing a scope does, not the whole process.
    • SuperNurd says:
      Analog is always the way to roll when scoping, but if you don’t own an analog osciloscpe then digital is still progress away from nothing.
      • Zee says:
        Oh lord. Analog snobs. Give me one concrete example where an analog scope is better
      • analog says:
        For microphone and preamp development work, I’ll take an analog scope all day long over digital.
        My analog scopes will likely be working in 10, 20, 30 years. Good luck with digital scopes. Many are just PC’s running windows, with a sampling card.
        The analog scopes work extremely well and they work cheaply. A 5000 or 7000 series tek, with a vast array of inexpensive plugins, is a great example.
        The waveform display resolution on many digital scopes is awful.
  10. well I find it interesting on the cheap but still it does not create a setback in the long run that thing sure is not good as they say they
  11. qwert says:
    Am I stupid, or should the resistors in his example be swapped? 82/(18+82) is not much of a voltage divider…
  12. Bogdan says:
    This one is a whole lot better for not much money in parts:
    http://projectproto.blogspot.sg/2010/09/android-bluetooth-oscilloscope.html
  13. harviecz says:
    WOW. He installed oscope app from android market and he is using it in way that it’s supposed to be used. Such Hack!
    app is made by university student as school work, so it was probably meant to be used just like this (and not without microphone)
    if you think it’s cool you should write about app creators not about it’s users
    BTW quick tip: use two antiparalell zener diodes between ground and signal to protect microphone input from overvoltage
    you can also use potentiometer instead of voltage divider to have wider range of measurable voltages (at least when in lower freqs).
  14. Anka06 says:
    Like your project!
  15. Ren says:
    Is there a spectrum analyzer app for that?
  16. Clint says:
    Is there a Parts list for this I couldn’t hear Some of it
  17. Clint says:
    all these android oscilloscopes only seem to work with sound
WordPress.com Logo
Twitter picture
Facebook photo
Connecting to %s
