Recovering from a Seagate HDD firmware bug
Hard drive firmware is about the last place you want to find a bug. But that turned out to be the problem with [BBfoto's] Seagate HDD which he was using in a RAID array. It stopped working completely, and he later found out the firmware has a bug that makes the drive think it’s permanently in a busy state. There’s a firmware upgrade available, but you have to apply it before the problem shows its face, otherwise you’re out of luck. Some searching led him to a hardware fix for the problem.
[Brad Garcia] put together the tutorial which illustrates the steps needed to unbrick the 7200.11 hard drive with the busy state bug. The image in the lower right shows the drive with a piece of paper between the PCB and the connectors which control the head. This is necessary to boot the drive without it hanging due to the bug. From there he issues serial commands to put it into Access Level 2, then removes the cardboard for the rest of the fix.
In the tutorial [Brad] uses a serial-TTL converter. [BBfoto] grabbed an Arduino instead, using it as a USB-ttl bridge.
Comments
  1. Nunya Bizniss says:
    I went through this too awhile back. I used a BusPirate.
  2. Arvydas says:
    I did exactly the same thing about three weeks ago and detailed the process in my blog :)
    http://www.arvydas.co.uk/2012/07/fixing-a-seagate-7200-11-hard-drive-with-arduino/
  3. Asdf says:
    and that ladies and gentlemen is why one should have ran the firmware updater tool *Before* something happened.
    I have 4 7200.11’s I flashed in a RAID-Z array. Have had zero problems before or after.
    • GS says:
      Everyone knows you don’t fix what isn’t broken. This should be a voluntary recall, or a fix from the manufacturer for price of shipping one way. But at the price of HDDs now, price of shipping would almost be useless, much like what happened to me shipping a $40 shredder for $60 when it failed less than 4 months of use.
      Some good a 1 year warranty is.
    • Pilotgeek says:
      I think the problem is, a lot of people don’t know they have a hard drive with that bug until the problem happens. Sure, you may buy a hard drive knowing it has that bug, but many people may have bought it without knowing of the bug, or realizing that their drive is effected.
    • Yeah, that’s great that you knew that the hard drive firmware was hooped but I’ve never had a hard drive fail since my first XT computer with a 40MB drive (1989). Well, until now that is… I do now have an unresponsive 7200.12 hard drive that undoubtedly has a firmware bug if not the same firmware bug are the 7200.11. It showed up with absolutely no warning. One day the computer shut down for a reboot and never came back. Sad but true.
  4. sxrguyinma says:
    I need to try this with a bricked Seagate I’ve got sitting around…might be the same issue!
    • sxrguyinma says:
      Won’t work for me – mine is a 7200.10, not a .11 with the BSY problem. I’ve got TONS of old photos, videos and music on it that I need off. It’s sitting around till I can get some disposable income and send it out to get professionally recovered
  5. Nem says:
    I did this with a USB to serial cable with the end cut off. It was rather nerve racking typing obscure commands into hyperterminal…I hate not knowing what the commands do >.<
  6. m1ndtr1p says:
    And this is why I only use Western Digital hard drives now and avoid Seagate at all costs… Since they bought out Maxtor, Seagate’s quality control and overall reliability has gone down the shitter.
    Out of 12 Seagate drives I used in my server in the last 6 years, 9 of them have failed in some way, and of the 9 replacements I’ve gotten back from Seagate, 2 were DOA and 5 others have since failed… After that, I gave up and replaced them all with Western Digital Black drives, I haven’t has a single issue since.
    • Vonskippy says:
      So true.
      Remember when ALL Seagate drives came with 5 year warranties AND were still cheaper priced then the competition.
      Now Seagate is expensive and crappy.
    • crashsuit says:
      Ditto. I had a 7200.9 that went bad after a few months. I could’ve gotten it replaced under warranty but that doesn’t do anything for the thousands of family photos I had on there. Googled around and found out the 7200.9 drives were notoriously failure-prone. I won’t touch Seagate now.
  7. yn0t says:
    I noticed that one of the last steps was a partition format. Will this cause the loss of data or is this at another level?
  8. GZ says:
    This happened to me, Seagate repaired it free of charge. I appreciate that they owned up to their bug.
  9. Whatnot says:
    This is pretty old and several youtube howto’s were put up back when this bug hit the scene.
    It’s one of the reasons why I am very hesitant about using seagate drives, this and some other stupid things they did which should not have happened.
  10. doragasu says:
    This is pretty old (2 years maybe). I had 4 of these disks. I updated the firmware when it became available, and all the disks have been working flawlessly to day.
  11. Just me says:
    I too have done that, using BusPirate. Easy job.
  12. NewCommentor1283 says:
    does this fix the bug itself?
    or just reset the busy-state and put the drive back into a “ready to fail” state ???
    IE: does this fix it forever or does it just put it back into a state of “1/million chance of re-glitching” ???
  13. Sushi says:
    Used it on a friend’s bricked maxtor hdd. Works fine.
  14. E-TARD says:
    eeek firmware bugs sux.
    that’s flippin cool you can do that.
  15. Eric says:
    Once it does this and you fix it, never trust the drive again no matter what you do to the firmware. Get your stuff off and maybe use it for something you can afford to lose. I’ve fixed them, upped the firmware, and it goes bad in 6 mo’s anyway.
    Also, sometimes I’ve had to vary from the standard procedure to get one fixed. Like change what I’m disconnecting with the cardboard.
  16. matt says:
    I have a bunch of those drives is a series of RAID 5s (9TB raw capacity), 2 have died so far and I can’t send them back because they were OEM disks. I’m pretty sure you can’t update the firmware when they are in a RAID either. Anyone know how I could update it, with out pulling a drive from the array and having to spend god knows how many weeks rebuilding my array over and over again, all the while hoping that another drive doesnt die during the rebuild? The controller is a Highpoint 3520 if that matters.
  17. reliable_ssd says:
    i have an ocz vertex barefoot ssd that bricked due to the controller firmware taking a shit. anyone know of a fix for these? I would love to retrieve my data from it…
  18. Galane says:
    I had a 36 gig Maxtor drive in the millennium family that managed to lose the part of its firmware stored on the platters.
    I searched for a long time for a firmware file to use with the procedures I’d found to fix Maxtor drives. The millennium drives were the only ones I could not find any firmware for.
    For quite a while I’d look for some file, couldn’t find it on any of my drives… “Oh. It was on that POS Maxtor!”
    Western Digital in the pre WWW era had the best customer service. They had a dialup BBS with all their software and drivers. It also had a documentation lookup feature where you could find the numbers. The next step was to dial their toll free FAX-back service where (IIRC) up to four documents at a time could be requested. In a few minutes it’d FAX you the documents. Even more amazing was WD had software and documents for product lines they’d sold off to other companies. Remember the “Orchid” video cards? I got drivers and docs for them from WD after the company WD sold Orchid to had discontinued the line. Other companies (like Chaintech) would destroy/delete information on discontinued products and some went so far as to deny ever making some items, even with their current company name and address printed directly on the item.
    In later years, when a hard drive had to go back under warranty, WD had a minimum turnaround time. If they couldn’t repair the drive you sent in, they’d send a refurbished identical model. If they had no refurbished ones of that model in stock, they’d ship you a new drive. If they had none of that model at all, you’d get back a drive of the next higher capacity with at least the same spindle RPM.
    In contrast, the way Seagate would do warranty service was they would fix the returned drive, no matter how long it took. If the returned drive wasn’t repairable you’d get back a different drive of the same model. If they had none in stock you got to wait as long as it took for Seagate to get in an identical model. You would not ever get a new drive as a warranty replacement.
    IBM was even worse. They’d send out “certified” used drives. Once one of their “certified” drives didn’t work at all and on the day the second replacement arrived the customer’s original drive died completely, taking all her files to the digital graveyard with it.
    IIRC Maxtor and Quantum would replace warranty returned drives with new ones of the same model and refurbished ones if the drive was out of production. You’d never get a higher capacity or any different “equivalent” like Western Digital would do.
  19. sonofabit says:
    dang! he beat me to it! I’d fix my friends HDD months ago, but still can’t find my torx screwdriver :( i think it’ll be faster to order new one…
  20. Afterm4th says:
    I did this on a failed seagate. The firmware did appear to be at fault.
    This fix did not work for me
  21. Promethius326 says:
    In my shop I see about 75-100 hard drives a week and track the brand of bad drives. Frequency of failure from best to worst: Seagate, Western Digital, Samsung, Fujitsu, Toshiba, Hitachi. I no longer track IBM or Maxtor. I swore by WD until last year, then I ordered 9 drives, every one failed within 3 months. The frequency of bad drives has also increased with time, hard drives are not made anywhere near as well as they used to be, backup, backup, backup. Also worth noting WD and Seagate both chopped their warranty period 2 years regular, 3 for enterprise.
  22. Dragon_rex says:
    i’m looking for old firmwire sd15, new one doesnot support the repair way
    model st3500320as
  23. Sorry, correction, “500 GB SSD”
WordPress.com Logo
Twitter picture
Facebook photo
Google+ photo
Connecting to %s
Follow
Join 96,660 other followers
