i thought it was clever to boost the itrip mini with my lame little hack, and change what’s playing on cars next to me at stop lights, and then this project blows that out of the broadcasting waters. be sure to check with your local laws and all that before broadcasting with this “proof of concept” itrip amp.
This hack is lame… I made the itrip amp and hooked three units together and boosted the power input and it does nothing but increase your clean stations range.. its not powerful enough to take over radio stations farther than 2-3 feet away with the amp and it can’t even take over some at that.
the url is down anyone have a mirror
Yes a if there a mirror that would be great.. id love to try this out
Now how a bout a proof of concept project which amplifies the airport base station or express. Any takers?
Please.
i found this page without hackaday, but have come to hackaday to talk about it. Mastercg i doubt you’ll ever read this but am intrigued how on earth you got this to work ? its not clear to say the least, plus the schematic link is dead. i the schematic from another site. what capacitor did you use ? my 220 ohm resistor gets hot ??? would love some help and advice, cheers.
http://www.capsgetpeeled.com/blog/archives/000353.html
Guys, Just go but an FM mic. They are small and cheap. Hook them onto the head phone input. Get the FM mic with variable frequency adjuster. They have a range of 100 ft. You can over ride a popular radio station in Cars nearby you when stuck in a traffic Jam.
The chances of a flea powered FM mic transmitter overiding a broadcast station, are slim to none, as most of you are aware slim left town. The chances of this hack of doing so are similar. Thing is the moment the radio user tuned to the broadcast station, the broadcast station has “captured” that particular receiver, see http://www.atis.org/tg2k/_capture_effect.html
It works. And you can do it alot ez’r then this.
For a better transmit range there are more complex transmitters sold but seems to be almost illegal in power rating. this one should work well for a range within a meter from the car.
https://web.archive.org/web/20080516064503/http://www.binaryelysium.com/itrip_amp/
