Overclock The Pocket Pc
upclock the ppc
you can speed up (or slow down) many of the pocket pcs out there, just using software. speeding up things is the obvious fun thing, but if you’re looking to max out your battery life you can throttle the processor back, all from a control panel.
6 thoughts on “Overclock The Pocket Pc
  1. With a Dell AximX3i, I hear you can overclock it enough to run a playstation emulator at a playable speed, more than likeley soundless, but still…damn that’s cool.
  2. Using a hp pocket pc here, overclock it from 316 MHz to 520 MHz. A real boost for video playback, but still not enough to emulate GBA or Playstation.
