Welcome back to A-DJ-Hack-Every-Other-Day. Maintaining clean vinyl will improve the sound quality and lifetime of your records and cartridges. It’s also a great first step when ripping the audio. This record cleaning system is built from the platter of an old turntable and a canister vacuum. The record clamp is constructed from MDF and is used to rotate the record and protect the label. The vacuum hose has a modified crevice attachment used for removing the excess cleaning fluid. The site includes a recipe for making your own cleaning fluid. Of course any money you save on this project will probably be spent on more vinyl.
