While sitting in the heat at Defcon I wondered what the best activity for next year could be. I think liquid nitrogen ice cream has some great potential. It’s a pretty common freshman chemistry demo where you add liquid nitrogen to a standard ice cream recipe. As the -320degreeF nitrogen boils off it freezes the ice cream mixture resulting in one of the smoothest ice creams you’ll ever encounter. It is a simple task and you’ll see quite a few people that have tried it if you just google for it. Wear eye protection and heavy rubber gloves when working with liquid nitrogen. You’ll need at least a 5:1 ratio of N2 to ice cream. Mix it in a large metal container; a pressure cooker is probably your best bet. Most recommend mixing with a wooden spoon, but I think I’ll agree with DocBug “If it’s worth doing, it’s worth doing with power tools“.
[thanks XyTec]
