2.4Ghz Field Strength Meter
strength
This is a really simple way to measure WiFi strength. Actually, it will measure anything in the 2.4Ghz range, like your microwave. The device consists of a two element quad antenna, a Ghz sensitive diode and a variable capacitor for tuning. The sensor is plugged into a voltmeter for measurement. The page has links for locating the specialized diodes.
20 thoughts on “2.4Ghz Field Strength Meter
  1. this thing is cool. i wonder if he could build three of them and pinpoint the source of the emr. like if they were spaced out enough and he had some software that interprets the differences in strength…. bah maybe too complicated…
  2. ARRRGH! He doesnt specify EXACTLY which diode he used… I have a box full of thrift-store radar detectors and other door-opener gunnplexers, (all have SIMILAR microwave diodes in them) but theres no way to tell which will work best…
  3. HELLO, MY NAME IS PETER AND I LOVE ROSE. I HAVE BEEN MADLY IN LOVE WITH HER SINCE KINDERGARDEN AND I CANT WAIT TO SEE HER AGAIN. SMOOCHY SMOOCH ROSE. I LOVE YOU. KISSY KISS ROSE. I LOVE YOU. WOOOOOOOOOOOOWOOOOOOOOOOOOOO PIPIT. I LOVE ROSE.
  4. 1N5711 schottky diodes will work, and are much easier to find. To drive an analog meter, you’d need to buffer the diode’s output with an op-amp. For a accurate reading in dBm, look into the Analog Devices AD8313/AD8314 series of log detectors.
  5. Another good source for these microwave diodes is old radar detectors. Nearly any radar detector that uses a cast metal waveguide horn and mixer housing will have one or more detector diodes installed in their mixer stage.
    Some manufactures of radar detectors used “strip-line” waveguides and mixers, so these will have a double-sided p.c. board with
    tiny little “pellet”, surface-mounted diodes instead of a 3-dimesional “horn” assembly. These would, admittedly be much harder to de-solder/solder to without overheating and destroying them, but might make for a far more compact antenna assembly.
    Standard ESD precautions should also be observed to protect these types of diode/s from static discharge while handling and soldering.
    DC
  6. Ugly, but beautiful! I’m wondering if the guage of the copper wire makes a difference? It looks as though this person used a 12 guage wire for the elements. This would maybe make a good detector for tooling around the neighborhood in your car, seeing which neighbors of yours are using an 802.11g transmitter ;). Oh – and put me in for 10 on pete also.
  7. Ugly, but beautiful! I’m wondering if the guage of the copper wire makes a difference? It looks as though this person used a 12 guage wire for the elements. This would maybe make a good detector for tooling around the neighborhood in your car, seeing which neighbors of yours are using an 802.11g transmitter ;). Oh – and put me in for 10 on pete also.
  8. i just recently took apart my old Gameboy Color and noticed that at the top of it there are a couple of LED’s. i was just wondering if the Gameboy Color was originally meant to be able to control things remotely with its LED’s.
Leave a Reply to rc:lineCancel reply
