[Jan] noted that they’ve come up with an interesting, low cost method of 3d scanning over (Update: http://www.david-laserscanner.com/wiki) at the Institute for Robotics and Process Control. Once the software is calibrated with the preset background image, a laser line is run over the object (Just think about every sci-fi laser scanner you’ve ever seen) The software appears to measure the contour of the object by the breaks in the line as it’s passed over the object. Once a mesh of measurements is taken, the object can be reconstructed in the software. According to [Jan] “With Their technique they won the Main Prize of the “work group for Pattern recognition” this Year in Berlin.” Now, make it work under something besides windows and .NET.
Get your Design Challenge entries in! The 25th is rolling up on us quick!
