Given my obsession of CNC projects, I’m surprised that we haven’t mentioned this project before. [Dave] put together an excellent site about his CNC converted mini-lathe. (The same on that I’ve got) He built a pretty simple stepper controller to drive it. Since the lathe only needed two axis motors, he drove the steppers with some mosfets that he triggered from a parallel port. The site has been around for a while, but I thought you guys would enjoy a classic hack like this one.
7 thoughts on “CNC Mini-lathe”
Leave a Reply to vivCancel reply
Dave also makes one of the best CNC driver software packages (TurboCNC) available for the hobby/home-shop machinist, and it’s affordable at $65 with complete source code.
robotic regards,
Tom
Oh how I want…
Hey, I have some plans up on my site if you’d like to build your own real cheap and easy.
http://www.jfettigmachines.com/
Happy CNCing!
Jon
I’ve got the same machines as Will and I’m in the beginning stages. Designing the stepper driver right now.
Who has ideas for cheap lead drives? I wanted to couple directly but my stepper ain’t powerful enough.
had made a s/w to control a cnc lathe wihtout using G&M codes … provided a natural language interface for the CNC lathe (used VB AutoCAD and C++Open GL forthe interface and simulation)… if u need any info on this let me know
i have seen vgood projects i like to see
can i joint you grates web
can you please give a link to the s/w mentioned above
vb autocad & c++.
thx
mihir
