Recover Acer Aspire One From “failed To Initialize HAL” Error
The Acer Aspire One is a netbook that often ships with a Linux OS preinstalled. This is great for fans of open source as market share is calculated based on units shipped, not what users install after they buy the hardware. Unfortunately there is a pretty major flaw that can cause a “failed to initialize HAL” error as seen above. [Michael Crummy] came up with a set of steps you can use to recover from this error.
So what is this error? HAL stands for Hardware Abstraction Layer and it’s what allows one user interface to communicate with many different types of hardware. If you’re the proud owner of an Aspire One and are struck with this error you will suddenly find that you can no longer use the USB ports, card readers, wired or wireless network connectors, or the sound card. So you can’t connect to the Internet, and you can’t get any files on or off of the device using the currently installed operating system. For an OS that [Neal Stephenson] once described as “like the M1 tanks of the U.S. Army, made of space-age materials and jammed with sophisticated technology” this is a very big problem.
We know what you’re thinking… boot into a live session on a thumb drive and get what you need from the hard disk. Well that’s all fine and dandy, but you shouldn’t ever be forced to clean install Linux to fix a problem. So check out [Michael’s] method and make sure you turn off the Acer live update server which was mostly likely the cause of the problem in the first place.
22 thoughts on “Recover Acer Aspire One From “failed To Initialize HAL” Error
  1. Glad that he found a fix and I don’t mean to be rude, but it sounds like he has no idea what he did.
    I think it would be better to write up a batch script to automate steps 1-8 (twice) then have the user plug in and update. A script could easily be typed out by the user and run.
  2. What do you guys think of Acer? Are they generally reputable? I have an AR1600, for which there is almost no documentation, and absolutely no reference to it is made on Acer’s websites. And this… This is quite the fuckup. It’s like someone made a change and pushed it to the update server without ever testing it, instantly screwing over everyone unfortunate enough to run updates in that period.
  3. Indeed you are correct – I had no idea what i did, and I have very little knowledge of Linux commands(although I now know a little bit more!). Basically I tried a few commands suggested on the internet as a fix, none of which fully did the job. Eventually i stumbled across a combination which worked, and was repeatable – i restored the faulty partition from a backup repeatedly until I found the exact sequence of commands that did the job.
    As for writing a script – yes it would be a more elegant solution – but for the amount of typing required by the user I think it would be slight overkill.
    Many thanks for your constructive criticism.
    Mike C.
  4. @ turn.self.off
    I’m sure they probably have.
    Despite that, it would appear that there are still some out there in 2011 which are feeling a bit sick.
    In case there are any more I thought this info would be of some use to someone.
    Mike C.
  5. In my case I once had to recover from a broken grub install. The “trick” I ended up using was to boot from a liveUSB of the same distribution, mount the original filesystem in its own mountpoint,
    but replacing the /proc and /dev hierarchies with those from the liveUSB, and then chrooting on the copy of the machine that I have just created. From that point onwards it’s just a matter of fixing the broken packages with the package manager tools, so this procedure should work for any unbootable linux machine
  6. It’s nice to see a fix for this at last. I got so annoyed with this that I just installed Ubuntu on my AAO instead. Which is no bad thing because Ubuntu is infinitely better than that poxy “Linpus” distro it coms preinstalled with.
    Amusingly enough, installing Ubuntu would actually be a faster fix than following the steps outlined in this tutorial, but nevermind.
    The author might want to look up the “-f” switch for the rm command too :D
  7. Originally posted by wosser; “Amusingly enough, installing Ubuntu would actually be a faster fix than following the steps outlined in this tutorial, but nevermind.”
    Yes you’re probably correct – and if it was my machine that’s exactly what i would have done. This was a repair for someone elses machine so I wanted to retain the OS and files as much as possible.
    As for the “-f” switch for the rm command – many thanks for that – it would have made things easier, but as I no longer have the AAO I will leave the info on the web site as is.
    Thanks again
    Mike C.
  8. Odd, I have the opposite problem. I can’t find a netbook without the useless Windows 7 starter installed. Go on new- egg and youll read lots of complaints from people who will not get a refund for windows even when they refuse the EULA and install something else.
    The problem is that ACER and other netbook makers didn’t put any effort into properly configuring their OS.
    I regularly set up netbooks for my students. A USB stick set to boot and an internet connection are all that’s necessary. Several distributions of linux are specially configured for Netbooks, such as Mint, Puppy linux and even a version of Ubuntu for netbooks. 3 min on google should be all you need to find a link to the USB boot loader for these.
    1) set your BIOS to boot from USB.
    2) make sure you have an internet connection
    3) follow the instructions on screen.
    4) enjoy a much faster more capable Netbook without the brain damaged windows 7 Mobile.
    ACER is a good company I have purchased hundreds of thousands of dollars worth of their equipment over the years. The netbook itself is great, I just wish they would have taken a few min to put a decent distribution of Linux on their netbooks.
  9. The Aspire one is a great little machine but the linux ‘linpus’ build it ships with is awful. If you have one do yourself a favour and install ubuntu netbook remix instead.
  10. If you need a “decent” laptop, Walmart sells a compaq full sized laptop for 350$ that does most of what my clients need these days.
    Yes, it defaults to a Windows 7 install, but Ubuntu is tremendously friendly to all the hardware on it. It works better than the preinstalled Win7.
    Of course, it doesnt have things like a SD card reader, or webcam built in. It’s a wee skimpy on RAM and only 250GB hd.
  11. You know, if you’re using the Aspire One Linpus distro that came with the unit, you have bigger issues than the HAL error that might pop up… considering it’s Fedora Core 8 based and has been unsupported for about 2 years now.
    I know some people want to stick with what works…but at that point, UPGRADE ALREADY!
  12. Acer Linpus is a very bad O.S.
    Seems Acer haven’t idea about Linux and about SSD too.
    They makes a swap partition on Linpus!
    In my opinion they install bad versions of Linux to promote Microsoft O.S.
    Best thing to do is to fdisk again SSD and install Slackware Linux 12.2!
  13. Glen said… “do yourself a favour and install ubuntu netbook remix instead.”
    Yeah, actually that’s what I did in the first instance, however I found the performance was pretty dreadful, and it would take over a minute to get a wifi connection from a cold start.
    So I decided to install the “Normal” ubuntu Desktop (which is also available as a USB stick installer – very handy). I would recommend that course of action if you have enough internal disk space (I’ve got the 120gb spinny disk version). Runs like a dream on my AAO – very responsive and great hardware support.
    But all that said, I do appreciate the effort that was put into fixing this very agravating problem – perhaps people who buy AAO’s second hand will get the most benefit from it.
  14. I’m on my second Aspire one (10.1″) and these things are solid. My first one went down the stairs, was sat on, got hacked to hell and back and the only reason I got a new one was because the 521s have the new AMD / ATI chipset and DDR3 ram – it’s faster than balls. It’s actually sitting underneath my car seat and I use it occasionally in a pinch – everything still works solid (even though the plastic is starting to crack and I don’t have a wifi cover anymore), and I’m even running windows 7 ultimate with Aero.
    If you want an amazing netbook, grab an aspire one that suits your flavor, get 2gb of ram and an extended battery and be happy forever.
  15. OK, a little metooing:
    I also replaced Linpus with Ubuntu Netbook Remix, and even my wife loves it, to the point she no longer uses her crappy XP laptop anymore.
    Those Aspire One machines are wonderful for couch-computing.
  16. I have a ZG5 and removing the mta* files from directory /etc worked out also for me (just removing files and restart). Actually two of those mta??? files I could not remove due to some I/O error.
Leave a Reply to Michael CrummyCancel reply
