For those of you who haven’t been paying attention in class, here is the best of what has hit our blog this past week:
In the #1 spot is a post about a project where some pretty ambitious hackers found a way to run Linux on a digital picture frame. Bravo!
Next up is a post where [Chris] needs some help getting his 1/10th scale, cycle accurate Cray I ‘supercomputer’ to boot.
In third place is a post about a very elaborate 737 cockpit simulator that was built over the past couple of years. This is a pretty intense build with lots of details about how it was done.
Following that is a post about a 3D-printed device that is similar to a phenakistoscope but instead of using slits to allow you to see the models in succession, it blinks some LEDs at the appropriate times.
Finally rounding things out in fifth place is a post about Makerbot Industries’ most recent release, which will let you print out your own phenakistoscope. This 3D printer is bigger than their makerbot and optionally sports two extruders instead of one so that you can do dual colors or possibly dual materials.
