EL Wire Piping On A Party Couch
If you’ve been putting off that reupholstering project here’s a little incentive to get started. Adafruit now has some electroluminescent wire which is perfect for use as piping. They’ve outfitted a small sofa with the glowing material and we think it looks great whether switched on or not.
The installation process is really quite easy. The EL wire is covered with clear material that provides a continuous tab running the length of the wire. This can be stapled on like you see in the image above, or sewn into a fabric seam. So you could take an existing sofa cover, remove all the stitching, and sew it back together with the EL wire replacing the original piping. The video after the break shows how simple the process is.
This will be a nice complement to that Daft Punk table we’ve been meaning to build.[youtube=http://www.youtube.com/watch?v=7si_73v31I0&w=470]
10 thoughts on “EL Wire Piping On A Party Couch
  1. Am I not a 1337 h4xx0r since I do not know what “EL” means?
    Okay, I checked the tags of the post. Thank you, Tag. Electro-luminescent. :)
Leave a Reply to EmilNCancel reply
