Shown above is a fairly simple Raspberry Pi setup. There’s the Raspi itself, a 2.5″ hard drive, a USB hub, GPIO expansion, and wireless and Bluetooth adapters. Throw in the power supplies for all these devices, and you’ve got a real mess on your hands. There is a solution to this problem of a Gordian knot of USB and power cables: the Fairywren, a board that turns your Raspberry Pi into a Mini-ITX computer.
The basic idea behind the Fairywren is to take the basic outline of a Mini-ITX motherboard and add goodies like a real-time clock serial port, and USB hub while providing a secure mounting place for a Raspberry Pi. It turns a Raspberry Pi into a proper computer, with all the ports in the rear, and is compatible with a whole slew of Mini-ITX cases.
At £40, the Fairywren isn’t exactly cheap. In fact, it’s more expensive than the Raspberry Pi itself. That being said, you do get a whole lot of hardware for the price, and if you already have a small Mini-ITX case lying around, it may be just the thing to clean up the mess on your electronics bench.
wait, so this makes the rapsberry pi into an ordinary mini-itx computer that is more expensive but less powerful than an intel atom? I guess it does have GPIO, but we used to call that a parallel port…
New cloud computing is the old distributed mainframe.
New Chrome books are the old dumb thin client.
New facebook wall is the old homepage.
And so it goes.
The worst part is: all the while telling these lies, the people who coin the terms and use them, actually think that they are being honest.
Or buy a more powerful platform that is itx factor.. the Olimex boards. they even have one that has SATA.
The USB A to USB A cable necessary for their USB hub is nasty. It has the potential to damage USB devices if used incorrectly to hook two USB hosts together. They should have put a USB B socket on the board, or terminated it to a 4-pin header or similar.
Why would connecting one usb host to another be an issue. They should both be putting out ~5 volts… Is a USB TX line really going to fry if you send digital pulses at it in the wrong direction or for that matter, even in both directions? I guess it could be confusing if you weren’t paying attention, but I highly doubt it would damage any hardware.
The D-/D+ pins probably aren’t much of an issue, but the power pins could be. Devices like the Raspberry Pi provide no diode protection of the USB port power supply, so by connecting two Raspberry Pi’s together with a USB A to USB A cable, you could well be overloading the 5V regulators on one of the boards, as regulators don’t work well in parallel[1].
There’s also no guarantee as to the relative relationship between the 5V pins on two different host devices, so if one device effectively used -5V for GND and 0V for +5V, while another device used 0V for GND and +5V for +5V, you could end up shorting out the power supplies.
Standards exist for a reason, and the standards state categorically that USB A to USB A cables are wrong.
[1] A similar but related issue was discovered in the first revisions of the Raspberry Pi board, where the Ethernet chip was being overloaded try to provide 1.8V for the entire board, while the 1.8V regulator sat idle. http://www.raspberrypi.org/phpBB3/viewtopic.php?f=29&t=14489
USB A-A- is an awful heresy, it’s striclty forbidden by the usb spec and I can’t believe you can still buy them.
A 5V input header would have been a good alternative to the boring atx socket.
Moreover the project is not clear: what does “some of the money will be used for manufacturing” means? This project owner clearly does understand nothing about manufacturing electronic things.
Will not be a backer.
Personally i like the idea and believe it has some real merit, however reading through the entire thing and dealing with small businesses every day their Risks and challenges sections is no less than a huge red flag with a bright red flashing light behind it saying stop to me. I hope they prove me wrong but their wording in that just scares me.
*Touches finger to nose* me too. Perhaps I will wait for the knockoff. As others have stated, there are many other more cost effective ways to accomplish the same goal.
Can anyone point me to a source for short USB or Ethernet cables as used here? Shorter cables would make mounting a Pi in any case much easier e.g an old router case.
http://monoprice.com is where I go first to find oddball cables.
+1 monoprice. They are getting more expensive these days, however. everything I’ve bought is legit! TV wall mounts, Desk monitor mounts, Cat5e, hdmi, 8port gigabit switch, displayport changer, etc. I’ve read that their new hi-res monitors are supercool!
All good feel and quality, but <Wallmart prices.
…Albeit the prices are going up.
The only item I’ve gotten from them that was a worthless piece of scrap was an optical audio to coaxial audio adapter. It never worked, and when I cracked it open, it consisted of an I/C with a few resistors and an optical receiver that wasn’t even connected. Even after soldering the receiver to the board it didn’t work.
Otherwise, I’ve never had an issue with them, and small orders with a few short cables should be very cheap on shipping since they default to USPS in the States.
Buy a decent RJ45 crimping tool and a bag of plugs. You’ll be able to fix leads that have had the latch tab broken off and make patch leads to the exact length you need.
What kaidenshi + Fritoeata said about monoprice for general cables and other bits.
if i was gonna go through the trouble of getting a mini itx adapter board i think i would get an actual mini itx mobo with some more beef than a raspberry pi can offer. pi is ok if you are not expecting to connect every peripheral you have to it.
id rather see pi sized board that is stackable that has an integrated 5v switch mode supply, usb hub and perhaps some gpio breakouts and come with a case that can hold both that would be cool (and might exist already), but this is kinda overkill.
https://www.olimex.com/Products/OLinuXino/A20/A20-OLinuXino-MICRO-4GB/
Using a Pi this way is just dumb. The olimex board is faster, better, has far FAR more gpio and options.
I dont understand why hackers are being completely dumb and sticking with a RasPi when they can pick a better board when they need the sata and other features.
Or: http://cubiestore.com/collections/home-slide/products/cubieboard2
Well they might know about the olimex board. Do you know if you can get them in the US?
While we are on the subject I would love to see someone build an ARM board with some PCIe slots. I found at least one company that makes a chip SOC that supports it. http://www.arm.com/community/partners/display_product/rw/ProductId/3658/
even without slots it opens up some interesting options using the PCIe to add functions on the main board.
One with Ethernet, and USB 3.0 and USB 2.0 would be an interesting modern Commodore 64 just use external devices for mass storage. Maybe add ESata as well for mass storage.
One with just an 8x slot and an SPI interface ethernet port for a game machine. Pick your own graphics card when the drivers are ported. Or use it as a GPU compute node.
Or a desktop replacement/NAS with Giga-e, sata, and a mini pci to add wifi.
The hummingboard has a mini-pcie slot: http://www.solid-run.com/freescale-imx6-family/hummingboard/
You can also buy it as a module to put on your own board: http://www.solid-run.com/freescale-imx6-family/imx6-som/
There are also quite a few arm boards with PCI-E or PCI in the wireless router world. Google on Mikrotik Routerboard.
While this is cool. The reason I got a Pi was to use it more as an embedded platform. Essentially as an Arduino replacement with a boost in processing power.
So far the only Directly Pi related peripheral I have seen need for was a breadboard breakout for the GPIO. The only USB it has at present is a WiFi dongle, Putty works great.
Really if I had wanted a Mini-ITX system I would have bought a Mini-ITX system.
Screw this Mini-ITX. I’m going to make a Raspberry Pi based MTX board. 356mm X 425mm of PCB goodness. I’ll build my own board with Blackjack and Hookers!
You’re going to build your new board with Las Vegas?? B^)
+1 for the bender reference :)
On the moon?
In fact. Screw the MTX board. I’m just using the blackjack and bookers.
that’s only 2/3 of the fun…
The MTX board is so big having the black jack and hookers on it is what makes it useful.
You can say it is an expensive usb hub
Actually not, cause u still has 2 USB port at the back.
Wait, people actually using the pi as a REAL computer ? They sure are living in a dimension where time flies faster than ours by some orders of magnitude.
use a notebook lcd with digitalizer on top and you get a raspi tablet
When you need a HDD and all the peripherals. The Raspberry Pi is likely a wrong choice anyway.
… at which point, just buy a cubieboard, which is dropping in price and FAR more capable than the pi. (and actually has USEFUL pinouts)
Really don’t see the point in this at all, just turns it into a Mini-ITX computer, if you want one go buy one? It kills the point in the Raspberry Pi, It’s a small and neat computer. Pointless putting a PCB on another PCB to give it the features of some extra USB ports, currently working on a case which will have most of the features this will.. hopefully
