We’re assuming [Toumal] was desperately bored one day, because in the depths of the Internet he found some really cool components to build a solid state Geiger counter.
The Arduino and touchscreen are rather standard fare [Toumal] picked up on eBay for about $30. What really sets this project apart from all the other geiger counter builds we’ve seen is the solid state geiger counter [Toumal] used. This device uses a specially-made photodiode made by First Sensor to detect gamma emissions from 5 to 1000 keV.
[Toumal] put all the software for his Arduino touch screen radiation detector up on github. To be honest, we’re really impressed with the rad sensor [Toumal] used for this project, so if you ever decide to pick one of those up, he’s got your back with an Arduino library for it.
ok, so he basically implemented what is displayed on the main sensor product page.
Well, yeah. Except I wrote the whole UI and improved the sensor and display library a bit.
There’s not much you “do” with a radiation sensor output. And this sensor has an accelerometer output so I’d say it’s a bit more involved than a geiger tube shield.
But yeah, as I said on the page, it’s not gonna set the world on fire.
As long as it goes “Ding!” when there’s stuff, I’m on board with this.
How tricky would it be to extend this to read Alpha, Beta, and Neutron emissions as well?
Alpha is impossible with this detector, neutrons could be detected by “activation” with a suitable medium, but the detection efficiency is horrible (you need a butload of neutrons to detect anything at all) and response time is…long…
Beta could be done indirectly by letting them produce braking radiation (Bremsstrahlung) with a suitable target (thin, but very dense metal)…
If you want a universal counter (not spectrum measurement), plastic scintillators are the way to go ;-)
looks good. I notice that photodiode is only $78 bucks in quantities of one.
Yup, it’s really quite affordable. Sadly you can’t mount it on a car or anything with lots of vibration because it’s very sensitive to mechanical influences – hence the dedicated noise (=accelerometer) output.
Check how much do NaI(Tl) scintillators or even HPGE detectors (the best detection tech available) cost :P
great hack, though you can buy a GM-Tube for the same price as that expensive diode..
Just in case it’s useful to anyone else: that photodiode is most sensitive to x-rays, between about 2.2keV (0.56nm / 0.53EHz) to 20keV (62pm / 4.8EHz)
Thanks, I was about to point that out, with much less accuracy.
Just because the curve goes wider, doesn’t mean the detector is necessarily much good out there. It’s on a log-log scale. Still, if you knew what material you had (and it’s gamma emission spectra), you could scale the count-rate by the insensitivity factor to correct somewhat to the true count rate. “somewhat” because you’ll also overestimate counts due to background, so you should only do it after subtracting the background counts. (you probably don’t want to “build in” such a factor.)
What would be really interesting is whether this sensor can be fooled by stuff like solar activity and the likes. Because otherwise I’m rather worried what’s going on at my workplace…
How do you test that it’s working without going into a dangerous environment. Would you need to do something like remove the source from a smoke detector, or are there more benign ways of getting a (non-dangerous) amount of gamma radiation?
You can get reference radiation sources. These are typically used for education and for calibration and function tests.
Various household items do give off measurable radiation, but if you want to be accurate you can get calibration sources online.
This is important – without proper calibration, such a device is just a worthless toy.
Just by turning it on it should already should some levels of radiation. Also, if I am not mistaken, some materials like granite emits radiation.
Granite, shales(can be quite hot) , bananas, smoke detectors, most masonry/dimension stone, basements if there’s a bunch of radon leaking in… The list goes on.
Thoriated lantern mantles are widely available and generate a bit of radiation, alpha if I recall correctly. It doesn’t penetrate far. I’ve used one to verify a geiger counter was working after part replacement, but only got a clear count by removing the counter’s outer case and pressing the mantle right up against the detector tube.
Alphas are difficult do detect (impossible with this detector), but the thorium decay chain has plenty of isotopes that emit beta* and gamma radiation which this sensor should detect…
*probably will not detect betas themselves but rather the braking radiation they produce when they impact the sensor wall ;-)
Verifying it reads “something” doesn’t mean it is working correctly.
About thirty years ago in California, some idiot walked into an office with an uncalibrated Geiger counter, turned it on and “measured” high radiation levels around some computer monitors. This resulted in a walk-out followed by all sorts of panic and lawsuits. Later, some engineers from the company that made the monitors got their hands on the device and checked it (it had been rented from a rent-all store) – it was not calibrated and gave high readings on anything. After calibrating it, they used it and another unit to re-test the monitors and showed no radiation from them. However, there was a higher background radiation than expected in the room. It turned out the paint on the walls was contaminated!
Looking at the technical documents section at http://www.radiation-watch.org the detectors (not the sensors) seems extremely hackable. To begin with they are open hardware licensed under CC-by. :-)
They mention among other things that a copper filter will give a more linear response and that the detectors (obviously) will saturate when the cps (counts per second) reaches the sampling rate, which at a sampling rate of 44.1 kHz will happen at a dose rate of 10 mSv/h (according to Wikipedia an *acute* dose of about 5 Sv can be fatal).
maybe its because i never learned japanse, but the documentation on this stuff seems quite unlinked on the page. Do you have an further reference ( I just bought one), and it could save me time to figure things out myself.
Any idea on sensitivity and saturation point?
Beware I’m not read in on radiation, only the very basics of radiation detectors. If I’m not all wrong, the saturation point should be around 10 mSv/h (when connected to a smartphone sampling at 44.1 kHz).
Strangely enough I have not seen the sensitivity mentioned on either of the Radiation Watch site nor in the sensor data sheet, but the Dutch Metrology Institute certificate (http://www.radiation-watch.co.uk/VSL_cert_3320408.pdf) for the Type 1 detector (the FRISK mint box diy detector) mentions a sensitivity between 0.07 and 0.09 μSv/h/cpm in their test results.
That’s why I wouldn’t recommend their smartphone models. I mean it’s probably gonna be enough for most applications but using a hardware interrupt like I do in my fork of their library is removing that limit, so you’re left with the actual sensor saturation limit.
Saturation point is scary. Once the rate of radiation hits a certain level it will read read zero, while your receiving a high dose.
It sure is. And 10mSv/h wont be enough to measure fallout after a very large accident (or nuclear bomb, God forbid). We wont get there, but inside a reactor containment the radiation level can get in the order of 10 Sv/h and up after a severe accident.
After reading in a bit this week on the radiation meters on the market I stumbled upon an Atomic Energy Commission informational film in the SL-1 reactor accident on YouTube. One of the lessons learned was that there was a need for radiation survey meters which could go to ≥5000 R/h (no typo, that’s five *thousand* Röntgen, or about 50 Sv/h), but that is for use inside the confinement and with a burst reactor pressure vessel (to put it in perspective, a dose of about 500 R or 5 Sv is usually considered lethal). :-S
Side note: A possibly grave approximation is that 1 Sv = 100 rem ≈ 100 Röntgen (I say possibly grave, as the definition of 1 Röntgen has varied quite a lot).
No GM tube – NOT A GEIGER COUNTER!!!!!
Technically I believe you are correct. Then again, everyone calls it a car battery when it’s really an accumulator.
You can use an ordinary PIN diode, I’ve built two so far, and have one outdoors and graphing on an old desktop computer.
The second one is here on the work bench which is used to check samples. I use a large TO-3 decapped power transistor to detect alphas.
And yes there is a daily peak at ~ noon, with the lowest readings a bit before dawn. What I’ve noticed is most of the background radiation comes from dust blowing around on dry windy days, and the readings get quite low during and just after rains.
Hello. Are you still there? It’s been a long time since your message. If you’re there, can you share the schematic of the two counters you made?
Tell me what the counter to buy and where to connect to Mega
Hi,
Could you say me if would be possible use ILI9341_16 instead ITDB02 and URTouch instead UTouch in your project…
Thanks,
Cesar
