Ikea Desk Laser Cutter Combo
Abandoned DIY Laser Cutter installed in Ikea Desk
Craigslist can be a good source for finding someone else’s abandoned projects. Besides being extremely jealous, you’ll agree that [Mike’s] find is atypical of the normal Craigslist listings. He scored a 75% complete group of laser cutter parts for $500. That included the XY frame, stepper motors, Gecko motor drivers, optics, and 40 watt CO2 laser tube. He paired the laser parts with another Craigslist find, a $15 desk. A few more parts and 3 weeks of tinkering later, [Mike] had a working DIY mutant Ikea Desk Laser Cutter.
The laser cutter has a 23 x 14 inch work envelope and is controlled via Mach3. The X Axis of the frame had a little bit of wobble in it so [Mike] added a THK linear rail and bearing to stiffen it up. To add a little bit of mistake proofing to the laser, [Mike] put a water flow sensor in the laser tube cooling system. The laser will not turn on unless water is pumping to cool the laser tube. Wrecking your laser tube by accident would be a total bummer!
There was no Z-Axis assembly included with the online score. [Mike] made his own with a few lead screws, acme nuts, sprockets and chain. A manual crank resides below the desk, turning it raises and lowers the honeycomb bed. It is necessary to adjust the height of the work piece to ensure that it is the correct distance away from the laser. The optics should focus the laser beam at a point inside of the material being cut or at the surface of the material being engraved.
[Mike] tallies up all of his expenses for the project to be about $900. You can’t deny that having your own laser cutter is pretty cool and saving these abandoned parts to make said laser cutter is pretty cool too.
[Thanks Peter]
3 thoughts on “Ikea Desk Laser Cutter Combo
  1. Heh, I actually got my laser cutter off of Craigslist. I haggled down to $900, but that was for the full (almost) working unit.
  2. Lack of water really won’t wreck one of these tubes but it will effect the output of the tube while running. The bore need to be cool for the lasing process. I have ran one with just water in the tube and no flow and it runs fine for quite a while and then the output starts dropping off as the bore warms up. This was just with a little 40W, bigger ones may have more of an issue with mirrors heating up.
    1. Err, yeah it does.
      Assuming it’s one of the typical 40W glass tubes, they either overheat and the front mirror falls off, or it goes bang and cracks.
      Dunno how long they take to overheat (wasn’t watching), but forgetting to turn the water pump on results in excitement pretty quickly.
      High voltage arcing and water – fun!
Leave a Reply to TonyCancel reply
