This year’s Red Bull Creation theme “Reinvent the Wheel” was pretty broad, but the Maker Twins managed to incorporate it quite closely with their winning project which was completed in under 72 hours. They took the idea of urban farming and figured out one way to make farmer’s markets more feasible by helping to eliminate waste and spruce up the presentation of the produce.
The project amounts to a Ferris wheel. Instead of passenger compartments there are modular crates which are built with one wooden pallet each. The wheel itself is chain-driven and allows the system to track where each crate is in the rotation. This data is leveraged for a couple of different uses. One lets the customer select their produce on a tablet app and the crate will rotate into position so they may pick the individual items they want. The machine will also take care of automated watering to ensure the produce on display doesn’t get dried out. The icing on the cake is a separate station for washing and cutting the purchased veggies.
Thank you to Maker Twins for contributing some demonstration “b-roll” for use in this video.
