Look around for a small, embedded camera module, and you’ll find your options are rather limited. You have the serial JPEG cameras, but they’re rather expensive and only have VGA resolution. A Raspi, webcam, and power supply is a false economy. GoPros are great, but you’re still looking at some Benjamins used.
The guys at GHI Electronics are taking a different tack. They’re using image sensors you would normally find in cellphones and webcams, adding a powerful ARM processor, and are still able to sell it for about $50. It’s called the ALCAM, and they’ve stumbled upon a need that hasn’t been met by any manufacturer until now.
On board the ALCAM is an OV3640 3-Megapixel image sensor. On the back of the board is a STM32F4 and a microSD card slot. The board can be set up for time-lapse videos, stop motion animation, or all the usual serial board camera functions, including getting images over a serial connection.
The ALCAM operates either connected to a PC though a 3.3V serial adapter cable, through a standalone mode with pins connected to a button or sensor, to the SPI bus on a microcontroller, or a serial to Bluetooth or WiFi bridge. Images can be saved to the uSD card, or sent down the serial stream.
It’s a pretty cool board, and if you’re thinking it looks familiar, you’re right: there’s a similar DSI camera/STM32F4 board that was an entry to The Hackaday Prize. Either way, just what we need to get better cameras cheaper into projects.
