Hackaday Prize Semifinalist: Better DIY Aquaculture
The theme of this year’s Hackaday Prize is ‘build something that matters’. For a lot of the teams entering a project, that means solving world hunger, specifically though agriculture. Grains are great, but proteins generally taste better and [Michael Ratcliffe] is focusing his project on aquaculture, or farming fish and other aquatic life.
The problem [Michael] decided to tackle is feeding fish at regular intervals according to water temperature, the age of the fish, and how much food is already floating in the tank. This is actually a difficult problem to solve; fish grow better when they’re fed more than once a day. Currently, most aquaculture setups feed fish once a day simply because it’s so time-consuming.
[Michael] is using Pis, Arduinos, USB cameras, and a lot of experience in automation and control systems to feed fish in the most efficient way. The possibilities of the project are interesting; the best research says a more efficient feeding schedule can translate into a 20% increase in production, which is a lot of extra food for the world.
You can check out [Michael]’s introductory video below.
The 2015 Hackaday Prize is sponsored by:
2 thoughts on “Hackaday Prize Semifinalist: Better DIY Aquaculture
  1. Small correction: in the video Michael said research shows that proper feeding could translate into an even more impressive 40% increase in production (not 20%).
