Cute But Serious-Faced Automata Produce A Pour Over
robot-cafe-cartCheck out the great workmanship that went into [TonyRobot]’s coffee vending version of ROBOT CAFE at Tokyo Maker Faire 2016. We’d really like to see this in action, so if anyone has more success than we did at tracking down more info (especially if it’s video) let us know in the comments below. We spot laser-cut wood making up the clever scoop design (and the numerous gears within it) but simply must know more.
Technically this is less “robot” and more “automata“. The cart charmingly fuses vending machine practicality with a visual display… and a great one at that. The aesthetic of the Robot Cafe leaps over the uncanny valley and fully embraces lovable robot faces.
Coffee is ground by a manual-style grinder into a scoop, which is then dumped into a pour-over filter. The hot water is then raised from below to pour over the grounds. These characters can be reconfigured based on the needs of the venue. The creator page linked above has three pictures of the same cart and same robo-baristas, but they are fishing for sodas instead. The glass bottles are lifted through the hole you can see on the right of the cart’s counter, using a fishing line with a magnet to grip the metal bottle cap.
We were delighted when robot vending machines started to appear — the kind with a big glass window and a gantry that grabs your corn-syrupy beverage. But take inspiration from this. True vending nirvana is as much theater as it is utility.
[via Gizmodo Japan]
14 thoughts on “Cute But Serious-Faced Automata Produce A Pour Over
    1. I’ve always wondered if you could create on the fly reconfigureable plastic mold machine using something like this toy. data:image/jpeg;base64,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
  1. The builder definitely puts things online, but there’s not a peep (yet?) about these coffee-servers. I am even MORE interested in seeing a video after seeing his other pieces. Some of them go through pretty elaborate performances – looking at and nodding to each other before going into action, glancing at watches while waiting, and so forth.
Leave a Reply to blablablaandgabblerCancel reply
