If you’re enjoying a Western Canadian summer, two of the best ways to do so involve a hammock, or a boat. Seeking to improve on this mighty duo with a hammock-boat combo, [Jarrett] describes his progress at Vancouver Hack Space.
The boat he chose was a one-person catamaran with an aluminium frame and what appear to be inflatable pontoons, while the hammock is one designed for a garden or patio with a steel tubular frame. A design goal was to not modify or destroy the structure of either item, so the challenge was to securely mount the two frames together. A variety of false starts involving bent steel or aluminium were tried, followed by a final success with the aluminium tubes reinforced with more tube inside them, and the hammock attached with U-bolts.
The testing took place on what appears to be a public lake, and the contraption floated well. When it had been pushed out to a landing stage our intrepid adventurer boarded the hammock — and promptly the whole edifice tipped itself over, depositing him in the drink. Further experimentation revealed that balance was critical, and a revised position could achieve a stable boarding. He paddles off into the sunset as you can see in the video below the break, though as his friends remind him, without his beer.
Commercial hammocks are surprisingly expensive for what they are. Don’t worry though, if you find them to be beyond your budget you can always make a frame for one yourself.
Boammock?
Hammoat?
No, no, Jenny already told you: Bo(a)t H(ammock) = BotH. It’s Both.
Very good,
I salute you!
(Takes bow/) :)
I’d rather have the rigid pontoons of a Hydrobike under me.
(Pedaling/paddling?) one of those is a breeze!
https://hydrobikes.com/
How hard is it to tip over? Being tangled in a hammock underwater because some dick wanted to prank you sounds dangerous.
Side-to-side was not an issue, it was steady as a rock. Front to back, absolutely unstable without proper weight distribution. Entanglement was a serious concern, I kept a knife in my pocket, but it turned out to not be a worry at all, the hammock opens up nicely under water and I never felt unsafe (I am also not a good swimmer)
Sorry, the vertical video just took me right out of it.
Do you people not have vertical monitors?
Catemaran > catamaran
Aluminum > aluminium (linked article)
What’s wrong with proper English ?
you didn’t notice the mistakes next to aluminum. “tries, sollowed” should be “tried, followed”. at a sciencey level both spellings of aluminium are accepted by somebody
I commend you on this hack and willing to try in front of so many people. To be accepted as a hack from this group it has to have an Arduino or a 555 as part of the design :).
Where’s the beer cooler and fishing rod brackets?
I want to hack this with lipo batteries, a BLDC motor and a speed controller driven with PWM via a good ol’ 555. Adding an electric trolling motor is just too easy, lol.
