Russian Weather Satellite Reuses Name, Yields Images
Which Russian weather satellite has the name Meteor 2? According to [saveitforparts], pretty much all of them. He showed how to grab images from an earlier satellite with the same name a while back. That satellite, though, met with some kind of disaster, so he’s posted a new video about reading data from the new Meteor 2 and you can watch it below.
The interesting part, we thought, was that the software he’s using, Raspberry-NOAA v2, doesn’t know about this incarnation of the bird which has only been up for a few weeks. That means he had to find a satellite with similar orbital parameters. Eventually, the program will have the setup for this satellite.
We marvel that computer technology is to the point that he can casually say, “I have another Linux computer up on the roof…” In addition to using Raspberry-NOAA, he acquires data from the pass directly with his SDR. Things didn’t go very well, but watching the steps he tries is instructive. He uses a variety of tools and finally gets a better result.
The image was higher quality than the NOAA satellites, but he had gaps in the pictures, and he couldn’t figure out why multiple runs of satdump didn’t produce the same results. If you have an SDR dongle and an antenna, you can find links to all the software and try it yourself.
If you need an antenna or want to listen to NOAA satellites, we know someone who can help. While the video pokes fun at the Meteor 2 satellites failing, all these kind of satellites do eventually go offline.
12 thoughts on “Russian Weather Satellite Reuses Name, Yields Images
Leave a Reply to AndrewCancel reply
