Electro-Optical Control Of Lasers With A Licorice Twist
You’ve got to hand it to [Les Wright]; he really knows how to dig into optical arcana and present topics in an interesting way. Case in point: an electro-optical control cell that’s powered by ouzo.
OK, the bit about the Greek aperitif may be stretching things a bit, but the Kerr Cell that [Les] builds in the video below does depend on anethole, the essential component of aniseed extract, which lends its aromatic flavor to everything from licorice to Galliano and ouzo. As [Les] explains, the Kerr effect uses a high-voltage field to rapidly switch light passing through a medium on and off. The most common medium in Kerr cells is nitrobenzene, a “distressingly powerful organic solvent” with such fun side effects as toxicity, flammability, and carcinogenicity.
Luckily, [Les] found a suitable substitute in the form of anethole — a purified sample, not just an ouzo nip. The solution went into a plain glass cuvette equipped with a pair of aluminum electrodes, which got connected to one of the high-voltage supplies we’ve seen him build before for his nitrogen laser. A pair of polarizing filters go on either end of the cuvette, and are adjusted to blank out the light passing through it. Applying 45 kilovolts across the cell instantly turns the light back on. Watch it in action in the video below.
There’s a lot of room left for experimentation on this one, including purification of the anethole for potentially better results. We’d also be curious if plain ouzo would show some degree of Kerr effect. For science, of course.
8 thoughts on “Electro-Optical Control Of Lasers With A Licorice Twist
  1. I looked into this awhile back, and IIRC acrylic has a fairly large Kerr coefficient. At least, large in comparison to simple and easily available materials.
    The effect is proportional to the length of the apparatus, so if you want to play around with it use a fairly long square rod of acrylic. Pass the polarized light into one end and out the other, then use HV electrodes to trigger the effect in the length of the rod.
    I believe the effect propagates at the speed of light in the material, which is why Kerr optical switches can switch things on and off so fast.
Leave a Reply to NickCancel reply
