Fast Paper Tape For The Nuclear Family
We’ve enjoyed several videos from [Chornobyl Family] about the computers that controlled the ill-fated nuclear reactor in Chornobyl (or Chernobyl, as it was spelled at the time of the accident). This time (see the video below) they are looking at a high-speed data storage device. You don’t normally think of high-speed and paper tape as going together, but this paper tape reader runs an astonishing 1,500 data units per second. Ok, so that’s not especially fast by today’s standards, but an ASR33, for example, did about 10 characters per second.
An IBM2400 tape drive, for reference, could transfer at least 10 times that amount of data in a second, and a 3400 could do even better. But this is paper tape. Magnetic tape had much higher density and used special tricks to get higher speeds mechanically using vacuum columns. It was still a pretty good trick to move 4 meters of paper tape a second through the machine.
The reader needed a bit of TLC after spending decades stored in a chicken shed. What do you think it looked like after living with the chickens? Yep. That’s exactly what it looked like. Cleaning and painting ensued.
Most tape readers used either brushes to sense the holes or light sensors. This reader used light sensors because you can more easily reach high speeds with that technique. Also inside is a very large motor that runs a fan to cool the electronics. The same motor pulls the tape through the path using a mechanism that reminded us of a cheap 3D printer extruder.
And move it does. You can see the machine chew through a tape at the end of the video. A lot different than watching an ASR33 or Flexowriter reading a tape. Making a paper tape reader today isn’t very hard — and you could probably just use a webcam and some vision software. Paper tape wasn’t just for computers. They ran CNC machines, typesetters, and even taught Morse code.
8 thoughts on “Fast Paper Tape For The Nuclear Family
    1. Yes. What this device can do and the Colossus tape reader couldn’t, is start and stop quickly. And the Colossus reader needs the tape to be in a loop, while this reader can read loose sections of tape.
        1. Those attributes make the speed more usable.
          It’s like a consumer SSD saying it is faster because it has a sequential read of 14000MB/s, but it can only maintain that speed for 6 seconds till it drops to 150MB/s.
          Is that faster than an enterprise drive that can read at 9000MB/s all day every day?
          Sure…kinda…depends.
  1. Chem grad school 1978, a course in electronics applied to chemistry. Whereas the program the prof wanted to run was on many, many meters of paper tape, he made a paper tape reader that had no moving parts. Rather, he and his research student were the moving parts. Student pulled the tape through the reader while prof fed the tape from the other side, making sure there were no twists or tangles. Only issue was that student had to be sure that the tape never backed up as there was no way to deal with an error except to stop and start over (an early version of “turn it off, turn it back on’). I’m pretty sure they got close to 4 m/s tape speed.
Leave a Reply to PrfesserCancel reply
