Usagi’s PDP-11 Supercomputer And Appeal For Floating Point Systems Info
With an exciting new year of retrocomputing ahead for [David Lovett] over at the Usagi Electric YouTube channel, recently some new hardware arrived at the farm. Specifically hardware from a company called Floating Point Systems (FPS), whose systems provide computing features to assist e.g. a minicomputer like [David]’s PDP-11/44 system with floating point operations. The goal here is to use a stack of 1980s-era FPS hardware to give the PDP-11/44 MIMD (multiple instructions, multiple data) computing features, which is a characteristic associated with supercomputers.
The FPS hardware is unfortunately both somewhat rare and not too much documentation, including schematics, has been found so far. This is where [David] would love some help from the community on finding more FPS hardware, documentation and any related information so that it can all be preserved.
FPS itself was acquired by Cray in 1991, before SGI took over Cray Research in 1996. As is usual with such acquisitions, a lot of older information tends to get lost, along with the hardware as it gets tossed out over the years by companies and others. So far [David] has acquired an FPS-100 array processor, an interface card for the PDP-11 and an FPS-3000, the latter of which appears to be a MIMD unit akin to the FPS-5000.
Without schematics, let alone significant documentation, it’s going to be an uphill battle to make it all work again, but with a bit of help from us retrocomputer enthusiasts, perhaps this might not be as impossible after all.
24 thoughts on “Usagi’s PDP-11 Supercomputer And Appeal For Floating Point Systems Info
    1. “Ai Hardware, Explained’ video unloads on 32 bit floating point standard?
      1 Inaccurate multiply mantissa.
      2 In addition/subtraction smaller exponent increased to match larger exponent thus discarding fractional values?
      Internet posts unload on 64 bit floating point standards?
      1. the university i went to used to teach the noobs basic on a pdp-8/e running etos. one day i managed to log 13 users in. once the 13th user logged in, etos was never able to make it out of its idle loop.
  1. It is more than exaflops! Gotta have the bandwidth to get data in and out. 128TB memory on a fast switch like nunalink and cray slingshot. Cray 1 at 150MFLOP is now 2ExaFLOP on the Cray at LLNL El Capitan and Musk just bought the First Cray at 1 billion dollars.
  2. Hooo. Back in the day. . . . We had an pdp 11/24 providing the operator interface for an industrial chemical site. Amazing, big, slow, amazing. Then we swapped it for a fabulous fast pdp 11/73. The local guy called and said, must be a new hard disc, it’s so small.
  3. Ah Yes, I remember those FPS COprocessors when I was an intern back in mid 80’s at work here.
    We had one in the PDP-11 and one in a VAX11/750 for doing calcuations on fourier transforms on noise data.
  4. I have an FPS unpopulated PCB. It is the huge format at 16 x 20 inches! They used a generic layout of rows of holes for DIP Wire-Wrap, like DEC did for backplanes and many of their production boards. Every unit could be different depending on available parts and hardware changes as long as it interfaced and correctly calculated.
