A Prototyping Board With Every Connector
Prototyping is a personal affair, with approaches ranging from dead-bug parts on tinplate through stripboard and protoboard, to solderless breadboards and more. Whichever you prefer, a common problem is that they don’t offer much in the way of solid connections to the outside world. You could use break-out boards, or you could do like [Pakequis] and make a prototyping board with every connector you can think of ready to go.
The board features the expected prototyping space in the middle, and we weren’t joking when we said every connector. There are analogue, serial, USB, headers aplenty, footprints for microcontroller boards, an Arduino shield, a Raspberry Pi header, and much more. There will doubtless be ones that readers will spot as missing, but it’s a pretty good selection.
We can imagine that with a solderless breadboard stuck in the middle it could be a very useful aid for teaching electronics, and we think it would give more than a few commercial boards a run for their money. It’s not the first we’ve featured, either.
32 thoughts on “A Prototyping Board With Every Connector
      1. The computer end was a DB25. (And, yes, serial went from DB25 to DB9 in the 1980s, and VGA is DB15 high density.)
        The really fun part with parallel cables was the Centronics connector on the other end, with its surprisingly resilient clips. (I think those are the only type of “clip” connectors that didn’t have “broken off” as their default state.)
      2. The U.S. military is really fond of the DB-50 and 37 connectors for their hardware, or at least for a lot of their stuff that’s slowly becoming legacy systems. Lost track of all the different adaptors I had to make to go from an old 50 pin to one of the odd “keyed” barrel type connectors they use.
        Real pain to solder the back of those round plugs.
  1. no no no. you’d be much better off doing one with about 4 sets of pin headers and a bunch of adaptors for each connector type. that would allow for any connector in a much smaller footprint and also allow non breadboard friendly components/modules.
  2. horrendously expensive way to do. I much prefer breadboards adapters for each connector: much cheaper and if you need more than one, just hook several of the same type. This large board is a waste. Like a luxury Swiss knife that will always lack the exact function you need.
    1. yeah and the psychological factor is severe too — the moment you find one connector that you need that it doesn’t have, you’ll feel like the entire thing is 100% useless. you’ll experience disappointment, on top of the practical problem.
  3. This is the problem with the modern way people get into “electronics”. So stuck in Arduino land that someone who has written 3000+ tech articles would feel comfortable claiming something for prototyping that did not even have things as basic as BNC, Coax, SMA or even a Banana plug had all connectors. Dinosaur rant over.
    1. Came here to say the exact same thing. This thing might be ok for beginner middle school kids but is missing so many essentials that it is e-waste. old man yelling at clouds rant over
  4. Beautiful to look at, and somewhat useful, but way less practical than say small breakout boards, each one with its connector, ready to be plugged in to a breadboard or contact strip, or soldered on a perfboard.
Leave a Reply to IIVQCancel reply
