A Gentle Introduction To COBOL
As the Common Business Oriented Language, COBOL has a long and storied history. To this day it’s quite literally the financial bedrock for banks, businesses and financial institutions, running largely unnoticed by the world on mainframes and similar high-reliability computer systems. That said, as a domain-specific language targeting boring business things it doesn’t quite get the attention or hype as general purpose programming or scripting languages. Its main characteristic in the public eye appears be that it’s ‘boring’.
Despite this, COBOL is a very effective language for writing data transactions, report generating and related tasks. Due to its narrow focus on business applications, it gets one started with very little fuss, is highly self-documenting, while providing native support for decimal calculations, and a range of I/O access and database types, even with mere files. Since version 2002 COBOL underwent a number of modernizations, such as free-form code, object-oriented programming and more.
Without further ado, let’s fetch an open-source COBOL toolchain and run it through its paces with a light COBOL tutorial.
Spoiled For Choice
It used to be that if you wanted to tinker with COBOL, you pretty much had to either have a mainframe system with OS/360 or similar kicking around, or, starting in 1999, hurl yourself at setting up a mainframe system using the Hercules mainframe emulator. Things got a lot more hobbyist & student friendly in 2002 with the release of GnuCOBOL, formerly OpenCOBOL, which translates COBOL into C code before compiling it into a binary.
While serviceable, GnuCOBOL is not a compiler, and does not claim any level of standard adherence despite scoring quite high against the NIST test suite. Fortunately, The GNU Compiler Collection (GCC) just got updated with a brand-new COBOL frontend (gcobol) in the 15.1 release. The only negative is that for now it is Linux-only, but if your distribution of choice already has it in the repository, you can fetch it there easily. Same for Windows folk who have WSL set up, or who can use GnuCOBOL with MSYS2.
With either compiler installed, you are now ready to start writing COBOL. The best part of this is that we can completely skip talking about the Job Control Language (JCL), which is an eldritch horror that one would normally be exposed to on IBM OS/360 systems and kin. Instead we can just use GCC (or GnuCOBOL) any way we like, including calling it directly on the CLI, via a Makefile or integrated in an IDE if that’s your thing.
Hello COBOL
As is typical, we start with the ‘Hello World’ example as a first look at a COBOL application:
IDENTIFICATION DIVISION.
    PROGRAM-ID. hello-world.
PROCEDURE DIVISION.
    DISPLAY "Hello, world!".
    STOP RUN.
Assuming we put this in a file called hello_world.cob, this can then be compiled with e.g. GnuCOBOL: cobc -x -free hello_world.cob.
The -x indicates that an executable binary is to be generated, and -free that the provided source uses free format code, meaning that we aren’t bound to specific column use or sequence numbers. We’re also free to use lowercase for all the verbs, but having it as uppercase can be easier to read.
From this small example we can see the most important elements, starting with the identification division with the program ID and optionally elements like the author name, etc. The program code is found in the procedure division, which here contains a single display verb that outputs the example string. Of note is the use of the period (.) as a statement terminator.
At the end of the application we indicate this with stop run., which terminates the application, even if called from a sub program.
Hello Data
As fun as a ‘hello world’ example is, it doesn’t give a lot of details about COBOL, other than that it’s quite succinct and uses plain English words rather than symbols. Things get more interesting when we start looking at the aspects which define this domain specific language, and which make it so relevant today.
Few languages support decimal (fixed point) calculations, for example. In this COBOL Basics project I captured a number of examples of this and related features. The main change is the addition of the data division following the identification division:
DATA DIVISION.
WORKING-STORAGE SECTION.
01 A PIC 99V99 VALUE 10.11.
01 B PIC 99V99 VALUE 20.22.
01 C PIC 99V99 VALUE 00.00.
01 D PIC $ZZZZV99 VALUE 00.00.
01 ST PIC $*(5).99 VALUE 00.00.
01 CMP PIC S9(5)V99 USAGE COMP VALUE 04199.04.
01 NOW PIC 99/99/9(4) VALUE 04102034.
The data division is unsurprisingly where you define the data used by the program. All variables used are defined within this division, contained within the working-storage section. While seemingly overwhelming, it’s fairly easily explained, starting with the two digits in front of each variable name. This is the data level and is how COBOL structures data, with 01 being the highest (root) level, with up to 49 levels available to create hierarchical data.
This is followed by the variable name, up to 30 characters, and then the PICTURE (or PIC) clause. This specifies the type and size of an elementary data item. If we wish to define a decimal value, we can do so as two numeric characters (represented by 9) followed by an implied decimal point V, with two decimal numbers (99).  As shorthand we can use e.g. S9(5) to indicate a signed value with 5 numeric characters. There a few more special characters, such as an asterisk which replaces leading zeroes and Z for zero suppressing.
The value clause does what it says on the tin: it assigns the value defined following it to the variable. There is however a gotcha here, as can be seen with the NOW variable that gets a value assigned, but due to the PIC format is turned into a formatted date (04/10/2034).
Within the procedure division these variables are subjected to addition (ADD A TO B GIVING C.), subtraction with rounding (SUBTRACT A FROM B GIVING C ROUNDED.), multiplication (MULTIPLY A BY CMP.) and division (DIVIDE CMP BY 20 GIVING ST.).
Finally, there are a few different internal formats, as defined by USAGE: these are computational (COMP) and display (the default). Here COMP stores the data as binary, with a variable number of bytes occupied, somewhat similar to char, short and int types in C. These internal formats are mostly useful to save space and to speed up calculations.
Hello Business
In a previous article I went over the reasons why a domain specific language like COBOL cannot be realistically replaced by a general language. In that same article I discussed the Hello Business project that I had written in COBOL as a way to gain some familiarity with the language. That particular project should be somewhat easy to follow with the information provided so far. New are mostly file I/O, loops, the use of perform and of course the Report Writer, which is probably best understood by reading the IBM Report Writer Programmer’s Manual (PDF).
Going over the entire code line by line would take a whole article by itself, so I will leave it as an exercise for the reader unless there is somehow a strong demand by our esteemed readers for additional COBOL tutorial articles.
Suffice it to say that there is a lot more functionality in COBOL beyond these basics. The IBM ILE COBOL reference (PDF), the IBM Mainframer COBOL tutorial, the Wikipedia entry and others give a pretty good overview of many of these features, which includes object-oriented COBOL, database access, heap allocation, interaction with other languages and so on.
Despite being only a novice COBOL programmer at this point, I have found this DSL to be very easy to pick up once I understood some of the oddities about the syntax, such as the use of data levels and the PIC formats. It is my hope that with this article I was able to share some of the knowledge and experiences I gained over the past weeks during my COBOL crash course, and maybe inspire others to also give it a shot. Let us know if you do!
19 thoughts on “A Gentle Introduction To COBOL
    1. I also got a small remark before reading the article. From what I’ve learned about COBOL and just reading snippets here and there, never trying to learn it for real (wonder why), the title suggested me a careful mother kissing the young IT boy’s head (that’s the “gentle” part) and wishing him success, then dropping 20 pounds of printed documentation over the same young IT boy (that would be the “introduction to COBOL”). If he’s lucky, the papers are still in the boxes after the echoes of the impact are gone. Now back to the article.
  1. Being a COBOL programmer is like being a mob lawyer – once you take that first job, there’s no way to go back to your old life. Be very, very certain this is what you want to do before you close that door behind you.
    1. “Be very, very certain this is what you want to do before you close that door behind you.” Of course there just might be some fringe benefits as one of the few experts in the field… Like flying your own jet to different clients and such, or that yacht you vacation on… Not for me though. Past the ‘get a new career’ stage in life.
    2. I’ve always heard how COBOL coders can make unlimited money, but I’ve always wondered what that really means.
      Obviously just learning the language, in itself, won’t get you a $200k salary (or thousands of teens would have done it). Is it that businesses want experience with their specific codebases, or is old code somehow especially arcane, or what?
  2. “It used to be that if you wanted to tinker with COBOL, you pretty much had to either have a mainframe system with OS/360 or similar kicking around,” – Not true, there have been PC versions of COBOL going back to the 1970s. I believe Microsoft even produced some. More recently MicroFocus has ruled that market, including one that ran on top of the .NET framework.
    Plus pretty much every business minicomputer/midrange had a COBOL implementation as well.
    1. Marketing and business folks talk about “pain points”. The huge honker of an easily checked mistake that you mention was the Disappointment Point of this article.
  3. I like the illustration too. ‘Real’ computers must have switches and lights. Just something about that, that appeals to me :) . While modern computers do the job, they just seem coldly ‘utilitarian’. Hard to put into words…
    Thanks for the article. Dabbling in Cobol is interesting. But that is about as far as I will go. With Rust, C/C++, Pascal, Python, Perl, assembly (ARM/RISC-V/x86_64) at my finger tips … Well, it is just not practical to add to the brain another language to be ‘proficient’ in that I’ll never use for anything.
  4. Fifty years ago, had the warning that COBOL was an obsolete language that was to be replaced immediately by ( insert your favorite other language here).
    Still waiting, retired five years ago. YMMV
  5. Fifty years ago, had the warning that COBOL was an obsolete language that was to be replaced immediately by ( insert your favorite other language here).
  6. Took a three week course when I started as a COBOL programmer at the start of the 80’s. It could probably have been done in one. I found coding with a pencil into gridded paper dull, and once I had been in the computer room and seen the 1900 serise ICL mainframe running GEORGE 3, that was where I wanted to be. Writing early database financial information services helped keep me interested for a few years but the move into tech support couldn’t come quick enough. I still have reflex twitches when I see a line of any code that doesn’t end with a period :-)
    1. Wow! When I was studying computing, we learned on the 1904a, also with George3! Among other things, we learned PLAN, and competed with other students for time on the MOPs. Sometimes we had to settle for an ASR33, but as time wore on we got to fight over visual terminals.
      WE COMERR… (IYKYK)
  7. Oooooh….
    I remember JCL.
    We had an IBM mainframe at Avondale shipyards when I went to work there in 1980.
    There was a guy named Harold Luke that was the JCL/Fortran wizard.
    I learned a little JCL, but it’s long gone.
  8. The language makes a lot of sense if you understand its historical context. The kinds of business processes that it automated were the sort that were either done manually — processing documents from “IN” to “OUT” trays (as seen only in cartoons these days) or using a card tabulator or sorter where one or more input streams of individual data records would be combined to form a new stream of data or tabulated to get some overall result. The language syntax is explained by the limitations of punched card data entry where it was common practice to start fields of a program statement on specific character column numbers. These are likely alien concepts to people brought up on interactive computing via a GUI.
Leave a Reply to I Alone Possess The TruthCancel reply
