Digitally-Converted Leica Gets A 64-Megapixel Upgrade
Leica’s film cameras were hugely popular in the 20th century, and remain so with collectors to this day. [Michael Suguitan] has previously had great success converting his classic Leica into a digital one, and now he’s taken the project even further.
[Michael’s] previous work saw him create a so-called “digital back” for the Leica M2. He fitted the classic camera with a Raspberry Pi Zero and a small imaging sensor to effectively turn it into a digital camera, creating what he called the LeicaMPi. Since then, [Michael] has made a range of upgrades to create what he calls the LeicaM2Pi.
The upgrades start with the image sensor. This time around, instead of using a generic Raspberry Pi camera, he’s gone with the fancier ArduCam OwlSight sensor. Boasting a mighty 64 megapixels, it’s still largely compatible with all the same software tools as the first-party cameras, making it both capable and easy to use. With a  crop factor of 3.7x, the camera’s Voigtlander 12mm lens has a much more useful field of view.
Unlike [Michael’s] previous setup, there was also no need to remove the camera’s IR filter to clear the shutter mechanism. This means the new camera is capable of taking natural color photos during the day.  [Michael] also added a flash this time around, controlled by the GPIOs of the Raspberry Pi Zero. The camera also features a much tidier onboard battery via the PiSugar module, which can be easily recharged with a USB-C cable.
If you’ve ever thought about converting an old-school film camera into a digital shooter, [Michael’s] work might serve as a great jumping off point. We’ve seen it done with DSLRs, before, too! Video after the break.
[Thanks to Stephen Walters for the tip!]
26 thoughts on “Digitally-Converted Leica Gets A 64-Megapixel Upgrade
    1. the hack, at least in the first version, is non-destructive.
      from the first post about his mod: “Perhaps the best thing about this conversion, and something which should propagate forward into other builds, is the way it does not hack or modify the original camera beyond the replacement of the already-removable back.”
  1. Sorry, but that’s a wasted effort. Sensor ridiculously too small. So many other cameras less desired or iconic to be sacrificed in this way. And not even as useful as Leica’s own digital cameras.
    1. I was going to say something similar.
      A good sensor has to be big, to catch most light and the fewest noise.
      The megapixels are secondary. The more, perhaps the worse, even.
      That’s why in amateur astronomy, in early 2000s, low-res CCD sensors from webcams had been used.
      They were low-res (ca. 320×240 pix range), but the sensors were light sensitive.
      Peeling off the UV filter was another modification at the time (because the photo taking was happening at night).
      1. Pardon my lack of knowledge, but why would the sensor size matter when you can use a lens to reduce the image size “at will”?
        I mean, I do understand that film can benefit from being bigger, as that would allow light sensitive particule to, proportionally, better represent the picture.
        And I also do understand that, in long exposure, very low light condition (like astrophotography), you need the lowest noise level possible (thus spreading the light and try to prevent heating of the sensor too).
        But here?
        Why would it matter to have a bigger sensor?
        I couldn’t watch the video, but I would assume that, by putting the sensor closer to the optics, you just refocus the image “as if” you used a bigger, farther sensor, no?
        1. It’s mostly because of the lack of depth of field. The smaller the sensor, the larger the depth of field, bringing essentially everything in focus – much like a cellphone camera vs DSLR.
          1. Oh I got it.
            So, seeing the size of this sensor, it will be way better than a cell phone, but also way worse than the original.
            Thanks for the explanation = )
    2. I’d not call it a wasted effort, yes a bigger sensor has many advantages but there are optical limitations to the lenses that means a sensor only in the centre of the ‘film’ is not really a terrible choice at least for some uses – though obviously you could crop a larger sensors output there but if you are going to do that all the time…
      Plus you get the advantages of having real lens family to choose from and a digital camera that means infinite shots for basically no cost and rapidly available results.
      Is it a modern Mirrorless, DSLR or otherwise high end speciality camera replacement obviously not, but that doesn’t mean its actually useless or a waste of effort. It is fun and functional, which is good enough in its own right, while also being the ideal camera to take to re-enactment type events set in its period for instance – being a good enough modern digital camera with all those benefits in a period body.
      1. I love your positive thinking here! 😃
        The journey is the reward, so to say! That’s the spirit!
        On other hand, this mod basically turns an SLR camera in a disposable camera from Fisher-Price. Quality wise, I mean.🥲
        And that’s okay. It’s surely a nice gag for the party, but simultanously makes lovers of film photography faint.
        1. Oh it should be way way over disposable camera, I’d not be shocked if its better than my old cannon DSLR by a big margin as smaller sensor or not the quality of the sensors has skyrocketed in the last few years and my old DSLR is an early 2000’s or maybe late 90’s model IIRC and this still has real lens to get the shot you want! Which is usually the more important part of getting the image you want anyway, potato or god tier sensor doesn’t do you any good if you can’t capture and focus the light ‘properly’…
    3. He explains this was the largest sensor compatible with a Raspberry Pi he could find. It’s also just ~60 USD.
      Cheap full-frame sensors for hobbyists are very hard to come by.
  2. The primary advantages of a film rangefinder Leica were superior lenses, the brightest viewfinder, and accurate linking of the rangefinder image to the lens focusing. He’s thrown it all away.
  3. I’ve long waited for an affordable sensor that would be somewhat the size of the 35mm film and sit nicely in place of the film. Insofar haven’t found one that I’d like, size, price, etc.
    The point of late DSLRs was large lenses combined with the large aperture … which lets more light through, etc. I know that the higher end smartphones’/tablets’ fisheye lenses combined with the advanced post-processing somewhat made those obsolete, but not without some drawbacks, like limiting the lens size (that’s why expensive smartphones have more than one sensor – to compensate for the smaller lens – and not only).
    What I am driving at is the optics where the most expensive part of the DSLRs, and they have gotten quite good and somewhat affordable (by the average Sam) some time mid-1980s, and there was a reason the most sold lens size back then was 50mm – it was the one that could get enough light to do surprisingly good photography, even with the cheapest film and the cheapest cameras. (again, average Sam snapping photos whilst, say, walking, not taking photos with tripod using higher-grade film).
    Having said that, advancements with the post-processing are actually quite spectacular, gone are some of the issues of the past; say, most of chromatic aberration (the edges of the lens being slightly out of focus and bleeding in more blue light than the rest of the lens) now can be just re-calculated and largely compensated for. That alone allowed making cheaper lenses with more defects that can be later compensated for; however, the old school analog DSLRs still had other tricks up their sleeves – the lens size being one of many (larger lens size … better zoom … etc).
    1. I’ve nearly finished replacing my old Nikon F mount lenses with new Z mount gear and I wouldn’t trade back a single one. The optics are way superior and correcting for inflation they’re not more expensive.
      The difference is so noticeable, even an otherwise “infamous” travel zoom like the 28-400/4-8 now takes sharper pictures than some of the more expensive older lenses. Some very strong advancements have been made over the last couple of years.
  4. I’m sure that it was a lot of fun doing this – but why not buy a Leica M8 or M9, Their not as big a sensor but you get wide angle which this doesn’t provide ( I’m a wide angel enthusiast).
  5. I would say this, I think it’s a great project to expand on. The choice of film body at this point really wouldn’t make any difference because of sensor limitations here you’re not re-creating the same image that camera would produce on film, but this isn’t trying to do that it seems. He built a new camera out of a leica frame. The tinkerer in me loves this project, the photog in me would struggle to conjur up the ambition to do something like this. I’d rather use that time shooting with my already built cams. But in the end, I can’t wait to see what new innovation he brings to the next model! Keep tinkering my friend!! Cheers
  6. It is a waste to use an iconic film camera, still in use today, to create a Frankencamera.
    People use Leica cameras to create that which is not attainable with any other camera system with or w/o Leica/ Leitz lenses.
    My 12year old Leica M240 with CMOS-24 mp sensor, a lens (10-90mm), plus a battery that lasts for WEEKS, will obliterate this wannabe camera.
    Plus, why recreate what has already done, when the cost is the same or less?
  7. I don’t understand the negativity in these comments. These older film Leicas will most likely never be used in their original way – why not do a fun project that wouldn’t harm the value of an antique? It isn’t so much the idea of “let’s make an SIIX competitor,” just the recycling of older, vintage, loved photography pieces.
Leave a Reply to I Alone Possess The TruthCancel reply
