Japan’s Venus Climate Orbiter Akatsuki was launched on May 21, 2010, and started its active mission in 2015 after an initial orbital insertion failure. Since that time, Akatsuki has continuously observed Venus from orbit until issues began to crop up in 2024 when contact was lost in April of that year due to attitude control issues. Japan’s space agency, JAXA, has now announced that the mission has officially ended on September 18, 2025, after a period of trying to coax the spacecraft back into some level of functionality again.
The Akatsuki spacecraft had six instruments, consisting of cameras covering the visible spectrum, ultraviolet and infrared spectra, as well as an oscillator for radio occultation experiments.
All primary mission goals were successfully completed in April of 2018, but engineers determined Akatsuki was capable of lasting at least another few years. This puts it well past its original design lifespan, and has provided us with much more scientific data than we could have hoped for.
Unfortunately, the shutdown of Akatsuki represents the end of the last active Venus mission, with much uncertainty surrounding any potential upcoming mission to Earth’s near-twin planet. The next potential mission is the Venus Life Finder, as an atmospheric mission penciled in for a 2026 launch. It would take at least until 2028 for a potential orbiter mission to launch, so for the foreseeable future Venus will be left alone, without its artificial moon that has kept it company for a decade.
10 years of data from Venus is still amazing. I’m sure plenty was learned about the planet and how to make the next orbiter more robust. Maybe next time they’ll use rope memory. :)
Mission accomplished! Data collected. What more can you ask.
Venus is such an enigmatic place. At some height above the surface is a band of gas that is a reasonable temperature. On Earth bacteria is found in the atmosphere higher than you would assume. Venus has a small sliver of habitability in that regard, a better chance for life than say Titan.
It’s almost too convenient.. At about fifty kilometers up, pressure and temperature are about the same as Earth, and also our breathable air is a lifting gas. And of course with no pressure differential, a leak is very slow and manageable. All you’d need to go outside is an oxygen bottle. It’s like Venus is daring us to come over and build cloud cities.
I wonder they solved the mystery of whether Venus actually has lightning or if the lightning-like radio signals from deep under the clouds are some other phenomenon. Venus is the only planet where supposedly there is lightning without a significant planetary magnetic field, but it’s not definitively proven.
