Detecting Surveillance Cameras With The ESP32
These days, surveillance cameras are all around us, and they’re smarter than ever. In particular, many of them are running advanced algorithms to recognize faces and scan license plates, compiling ever-greater databases on the movements and lives of individuals. Flock You is a project that aims to, at the very least, catalogue this part of the surveillance state, by detecting these cameras out in the wild.
The system is most specifically set up to detect surveillance cameras from Flock Safety, though it’s worth noting a wide range of companies produce plate-reading cameras and associated surveillance systems these days. The device uses an ESP32 microcontroller to detect these devices, relying on the in-built wireless hardware to do the job. The project can be built on a Oui-Spy device from Colonel Panic, or just by using a standard Xiao ESP32 S3 if so desired. By looking at Wi-Fi probe requests and beacon frames, as well as Bluetooth advertisements, it’s possible for the device to pick up telltale transmissions from a range of these cameras, with various pattern-matching techniques and MAC addresses used to filter results in this regard. When the device finds a camera, it sounds a buzzer notifying the user of this fact.
Meanwhile, if you’re interested in just how prevalent plate-reading cameras really are, you might also find deflock.me interesting. It’s a map of ALPR camera locations all over the world,  and you can submit your own findings if so desired. The techniques used by in the Flock You project are based on learnings from the DeFlock project. Meanwhile, if you want to join the surveillance state on your own terms, you can always build your own license plate reader instead!
[Thanks to Eric for the tip!]
42 thoughts on “Detecting Surveillance Cameras With The ESP32
  1. This wouldn’t be hard to defeat. Nevermind that it won’t catch wired-only cameras. For wireless cameras, it’s easy enough to have them store data locally then turn on WiFi/Bluetooth/etc. and “phone home” only at certain times or when certain conditions are met. If there’s enough demand for such a “wifi turned off except when it is needed” wireless survellance camera, companies will add this as a feature.
    That said, if there is NOT enough demand for a wireless-but-most-of-the-time-wireless-is-off camera, it won’t be cost-effective to put into mass production.
      1. Exactly. The ALPR camera’s are all WiFi on a mobile modem and solar panel. I haven’t seen one ALPR wired up. Now the Flock Condor may utilize wired connections as their usually PTZ cameras.
    1. Yes , I am wondering the same thing ! is there anything that can help to find hidden spy cameras ?
      let’s say I have an ex boyfriend who’s been known to put spy wear in someones house . Can I detect them ? I don’t know ANYTHING ABOUT ELECTRONICS. thank you, S.A.
  2. WiFi ? Is Flock building out their own network ? Are they using, and paying for, someone else’s network ? In urban areas I might expect either but some of these are on roadsides where I wouldn’t expect a WLAN to reach and so, wouldn’t they be “phoning home” ?
    1. Some Flock cameras have WiFi enabled, it is used for setup, it is unusual though for it to be left on. Additionally, Flock cameras with external batteries use BLE to monitor battery health.
    2. Additionally, I wouldn’t be surprised if Flock cameras do, or will start soon doing BLE sniffing since everyone just leaves bluetooth turned on on their phone and it is an easy way to track someone’s movements with sufficient sniffing devices.
  3. It’s easy to spot Flock ALPR cameras in my municipality, just look for the solar panel! The other model is the tow behind, Generac-esque looking thing. But interesting article for future use I’m sure… Besides I just use my smart phone and go Wardriving with the wiggle wifi app. Easy to spot with the help of Deflock!
    1. My friends and I used to joke that FedEx was part of a massive government surveillance program back in the 90’s; everywhere you went at the time, there seemed to be a FedEx truck nearby.
      Damn them for stealing my ideas!
      1. It will be coming to that if that’s what it takes I believe people are fed up with it china is fighting back against the system as we speak I don’t remember the name of the Band but they wrote a song about know your ENEMY and there video shows cameras all over town bob wire fencing know your enemies I see they are building a army of AI robots for policing WE THE PEOPLE and with that we are the answer to the problems in this country we are dealing with minutemenunite1776!
  4. I remember doing a paper for Electronics class in high school on the feasibility of using the IF of a heterodyne receiver to detect and triangulate through DF the location of said receivers of certain frequencies. Its major failing was that there is more than one way to skin a cat; 1+3=4, but so does 2+2. And there’s not a whole lot of signal leakage in the process; the world is a noisy place.
  5. On my iPhone 6 I could use the front camera at night to see the infrared glow from security cameras. Also IR remotes can be checked for functionality. Haven’t tried it on my iPhone X yet. Used to use developed but unexposed 35mm color film for IR filters.
  6. ALPR is a good thing.
    In my country (and I guess much of the EU), private entities cannot monitor outside their own ‘fence’. (There is an exception for banks).
    So all ALPRs are run by the police either on their vehicles or on intercity roads, typically motorways.
    We also only have one police force, so no small town two-person sherifs departments with their own ideas of use.
    How many ‘vans with stolen goods’ get caught I do not know, but a lot of uninsured, untaxed, uninspected and unlicensed vehicles and drivers are cought. So many, that when ALPRs first came into use, most offenders had to be ignored because of workload.
    The good part for my daily life? I do not get pulled and checked every month or so, as the police can concentrate on vehicles, that makes a ding in the police vehicle.
    1. Myself that’s going to a place and it’s only going to get worse if you don’t mind not enjoying your freedom I’m not even going to try to help you see this monster that is only going to take more from you than what you are able to see so sad! Our Great Country Our forefathers fought Bled And Died For the FREEDOM WE THE PEOPLE HAVE IN AMERICA AND I WILL BE ONE IF I MUST TO FIGHT AND DIE ALSO SO MY GRANDCHILDREN AND OUR BLOOD LINE EVEN AFTER THEM WILL KNOW WHAT IT MEANS TO ALSO REMAIN AND BE FREE I WILL NEVER LET THE BLOOD OF OUR FORFATHERS BE FORGOTTEN AND NEITHER SHOULD ANY OTHER AMERICAN PEOPLE GOD BLESS US ALL
  7. The problem is people have been dumbed down so much in this country. They no longer understand what freedom is much less the right to your privacy. Everybody is a Karen worried so much about what everybody else is up to! The Conservitives movement has spent the last 30 years scaring the hell out of everybody. So the could install their police state. People willingly give up their freedom for this promised protection from these Ghost criminals. Who are waiting on every street corner. To rape murder and make your kids do drugs! Hell now the gov just blatantly putting troops on the streets! People are just fine with that! But hey there #1 and free!
Leave a Reply to m0rd3caiCancel reply
