Assistive Radio Tells You What You Can’t See
We think of radios as audio devices, but for people who are visually impaired, it can be difficult to tell which channel you are listening to at any given time. [Sncarter] has a family member with vision impairment and built a radio to help her. Unfortunately, it was difficult to replicate, so he decided to try again. The result is an FM radio that provides audible status notifications about power and frequency. Check it out in the video below.
This isn’t just some hacked-up commercial radio, but a ground-up design that uses a TEA5767 with an ATMega328 for control. There is an LCD for when someone else might use the radio and an audio amplifier. He built the prototype on a breadboard, but moved the finished product to a PCB.
It isn’t just the electronics and the sound that are assistive. The case has raised bosses to help the user find things like the switch and rotary encoder. The Arduino can speak frequency announcements, although the quality of the voice is something he wants to tackle in the next revision.
These radios on a chip give you many design options. These same ideas can be useful for audiobook players, too.
2 thoughts on “Assistive Radio Tells You What You Can’t See
  1. Nice. I’ve seen some business and ham radios that will talk you through the menu settings and read off the frequencies as you change them. Thankfully, this feature can be turned off. Some even speak Chinese (because of course they do).
    It’s nice to see this in a simplified form factor for a normal consumer radio.
    1. My brother is a blind ham radio operator, and he uses a Kenwood radio with TTS functionality. He could also use a non-talking devices with Envision AI or Seeing AI reading him text, and ChatGPT explaining where is the menu function or button he needs.
Leave a Reply to DavidCancel reply
