Review And Demo Of The Zoyi ZT-QB9 Smart Clamp Meter
A hand holding the Zoyi ZT-QB9 Smart Clamp meter
Over on YouTube [Kiss Analog] reviews the New Zoyi ZT-QB9 Smart Clamp meter.
If you’re putting together an electronics lab from scratch you absolutely must get a multimeter to start. A typical multimeter will be able to do current measurements but it will require you to break the circuit you’re measuring and interface it to your meter using its mechanical probes.
A good choice for your second, or third, multimeter is a clamp-based one. Many of the clamp meters have the clamp probe available for current measurements while still allowing you to use the standard 4mm banana jack probes for other measurements, particularly voltage and resistance.
If you’re curious to know more about how clamp meters work the answer is that they rely on some physics called the Hall Effect, as explained by the good people at Fluke.
In the video the following clamp meters are seen: Zoyi ZT-QB9, PROVA 11, and Hioki CM4375. If you’re in the market for a clamp meter you might also like to consider the EEVblog BM036 or a clamp meter from Fluke.
We have of course posted about clamp meters before. Check out Frnisi DMC-100: A Clamp Meter Worth Cracking Open or ESP32 Powers DIY Smart Energy Meter if you’d like to know more. Have your own trusty clamp meter? Don’t need no stinkin’ clamp meter? Let us know in the comments!
9 thoughts on “Review And Demo Of The Zoyi ZT-QB9 Smart Clamp Meter
  1. “A good choice for your second, or third, multimeter is a clamp-based one. Many of the clamp meters have the clamp probe available for current measurements while still allowing you to use the standard 4mm banana jack probes for other measurements, particularly voltage and resistance.”
    Lower limit I believe.
  2. TLDR: he found an apparent 10% measurement discrepancy, but barely characterized it. The cheapo clamp meter may or may not be any good. Despite having a bunch of equipment that he might use as a reference to find out the actual current flow, he just compared it to a handful of other clamp meters that i frankly wasn’t convinced he actually knew how to use.
Leave a Reply to Keith PenneyCancel reply
