This Week In Security: DNS Oops, Novel C2s, And The Scam Becomes Real
Something rather significant happened on the Internet back in May, and it seems that someone only noticed it on September 3rd. [Youfu Zhang] dropped a note on one of the Mozilla security mailing lists, pointing out that there was a certificate issued by Fina for 1.1.1.1. That IP address may sound familiar, and you may have questions.
First off, yes, TLS certificates can be issued for IP addresses. You can even get a numeric TLS certificate for your IP address, via Lets Encrypt. And second, 1.1.1.1 sounds familiar because that’s CloudFlare’s public DNS resolver. On that address, Cloudflare notably makes use of DoH, a charming abbreviation for DNS over HTTPS. The last important detail is that Cloudflare didn’t request or authorize the certificate. Significant indeed.
This is a high-profile example of the major weakness of the TLS certificate system. There are over 300 trusted certificate authorities in the Microsoft Root Certificate Program, Financijska agencija (Fina) being one of them. All it takes is for one of those trusted roots to issue a bad certificate, to compromise that system. That it took four months for someone to discover and point out the problem isn’t great. Continue reading “This Week In Security: DNS Oops, Novel C2s, And The Scam Becomes Real”
