If you work with surface mount components, you might want an air pickup tool (sometimes called air or vacuum tweezers). You can find inexpensive ones that use a bulb or spring mechanism (like a solder sucker). While these are cheap, they don’t work very well. [Natsfr] had one of these cheap tools and decided to add a proper pump to make it work like a much more expensive tool.
