This hot air rework station is being used for more than just soldering surface mount components. Since it has settings for temperature and airflow [BrokeHippieTech] figured it would work as a bag vaporizer. In the video after the break they show off the custom parts and then take it though and herbal blend bag fill.
The hot air station comes with several different tips. The smallest one was used to mount a vaporizer bowl using high-temperature JB Weld. On the output side of the bowl a metal stem was also affixed to interface with the mouthpiece of a vaporizer bag. The heat from the rework station brings the herbs just below the combustion point, releasing the active ingredients without including the harmful byproducts associated with smoking.
We’re putting this one under medical hacks because we hope it’s being used responsibly and legally. As with the last vaporizer build we looked at, we have concerns about what else the apparatus may be putting into the collected gases.
Continue reading “Hot Air Rework Doubles As An Herbal Bag Vaporizer”
