So you’re getting better at programming microcontrollers and now you want to do several things at once? You know better than that, microcontrollers are only capable of processing one thing at a time. But if you’re clever with your coding you can achieve something that behaves as if several things are going on at once. The most common way to do this is to set a flag using an interrupt, then use the main loop to check for that flag. [S1axter] posted a tutorial on this topic where he uses bit field structures to help simplify time sensitive events.
We think [S1axter] did a fantastic job of explaining this moderately difficult topic clearly and quickly. In the video after the break he begins by explaining what a bit field is and how it is defined. Basically you’re using a C structure to track a flag using just one bit of storage. This way the flag is either set or not. We suggest you pay careful attention to how he declares the structures as volatile, so you don’t have unexpected behavior when you try it yourself.
Continue reading “C Bit Field Structures For Microcontroller Multitasking”
