Some of us may have recently stumbled over these mysterious ‘Mini 560’ synchronous buck converter modules at various e-shopping websites. These little modules claim to take in 7-20 VDC and output whatever voltage they’re configured for (e.g., 5 VDC). What IC is used on these modules? Since the IC on these modules has had its markings laser-etched away, answering that particular question is a tedious sleuthing job. Fortunately, [MisterHW] has done the legwork for us already, with a detailed write-up.
Details like the nominal input rating, measured currents, and resulting efficiency values provide clues. Looking at the 0603 SMD resistor values for given output voltages provides the programming resistances, combined with the footprint of the QFN-20 package. After desoldering the IC on a sample board, the footprint was reminiscent of certain Texas Instruments (Ti) packages, leading to a perusal of the Ti parametric database and a couple of candidate matches.
Continue reading “Hunting For Part Numbers: Analyzing The Buck Converter On Mini 560 Modules”
