Can A Scan Tool Kill A Car?
It’s no real secret that modern-day cars are basically a collection of computers on wheels, which also means that we get all the joys of debugging complex computer systems and software with cars these days. Rather than a quick poke under the hood to rebuild a carburetor and adjust the engine timing by hand, you’ll be pulling out a scan tool to gain access to the computer and figure out why the darn thing won’t start after someone else used a scan tool on it, as happened to [DiagnoseDan].
The question was whether the third-party scan tool that was used by the owner had done something to the software settings that would prevent the engine of this 2012 Renault Megane RS from starting, such as erasing keys, or if it was something more subtle. With no stored fault codes and the engine having healthy fuel, spark, and cam sensor readings, the conclusion was that the ECU was not doing its fuel injector things for some reason.
Ultimately, the root cause was that the ECU had been modded, with a re-mapping performed in 2020, meaning that the scan tool that [Dan] was using couldn’t properly interact with the ECU. Reflashing the ECU with the original manufacturer’s firmware was thus the next step, which is pretty involved in itself.
Reinstalling the OS on the car proved to be the solution. Likely, the modded firmware had stored some fault codes, as the ECU normally doesn’t start the engine if there are active codes stored. The third-party scan tool was thus likely blameless, but the inability to just clear fault codes was the real issue.
Continue reading “Can A Scan Tool Kill A Car?”
Control Everything In Your Car With The Car Kracker
If your whip is a Honda, Toyota, BMW, Chrysler, VW, or Mini made in the last decade or so, the Car Kracker is for you. This project allows you to connect directly to your car’s computer system, allowing you to display messages on your stereo, play music off an SD card, and even override factory settings like always-on daytime running lights.
The Car Kracker uses ISO 9141, an in-car communications protocol that is now mostly used in foreign (for the US) cars. The build uses a Gadget Gangster Propeller board to connect to the CD changer port and OBD-2 port in the trunk, and the diagnostic port located under the hood.
With the Car Kracker, it’s easy to connect the Aux In on your stereo to an SD card loaded with music, or even plug in an iPod for the poor souls without a 1/8″ jack. Dealer customizations such as turning the ‘door is ajar’ noise off, toggling daytime running lights, and throwing a nav warning up are also possible.
Check out the two videos after the break, and if anyone has any more info on getting this deep into a car’s computer system (a wiki, maybe?), send a link in on the tip line.
Continue reading “Control Everything In Your Car With The Car Kracker”
