Wouldn’t it be cool to extract 3D models from your favorite video games and then 3D print them? As it turns out, it’s pretty easy to do!
In the following video tutorial he shows us how to extract the 3D meshes from a video game called Chivalry, Medieval Warfare. The game is based on the unreal engine which makes it super easy to get the files.
Quick note on legality: If you choose to rip 3D models from your video games and print them, make sure you’re just printing them for yourself, not to sell.
To start, you’ll need a few pieces of software to help you out. First up is something called Umodel, which is an Unreal Engine Resource Viewer, which allows you to view and extract files from any game that uses the Unreal Engine. Once you find your model in the game directory, you can open it up in Umodel and save it as a .PSK file. From there you can open .PSK files with another program called Milkshape 3D, and then export in .OBJ file. Finally you can use MeshMixer to import .OBJ files, repair the mesh by removing the extra shells (you can use the cloud NetFabb service to help repair files for 3D printing as well), and then finally save as .STL ready to print.
