A photo of the old mechanical and new digital altimeters
Ben Eater Explains How Aircraft Systems Communicate With The ARINC 429 Protocol
Over on his YouTube channel the inimitable [Ben Eater] takes a look at an electronic altimeter which replaces an old mechanical altimeter in an airplane.
The old altimeter was entirely mechanical, except for a pair of wires which can power a backlight. Both the old and new altimeters have a dial on the front for calibrating the meter. The electronic altimeter has a connector on the back for integrating with the rest of the airplane. [Ben] notes that this particular electronic altimeter is only a backup in the airplane it is installed in, it’s there for a “second opinion” or in case of emergency.
Continue reading “Ben Eater Explains How Aircraft Systems Communicate With The ARINC 429 Protocol” →
