Madeline Gannon The Robot Tamer!
Let’s be honest. Who doesn’t want an industrial six-axis robot arm in their garage to do their bidding? Introducing [Madeline Gannon], the Robot Tamer!
The only tricky part is… if you received an industrial six-axis robot arm, would you be able to control it to do your bidding (easily)? Having taken robotics courses myself in college, and worked with ABB robots like this one, I can tell you, it’s not exactly plug-and-play. Yeah, there’s the teach pendant and you can pretty quickly teach the robot to do a repetitive task well, but unless you’re setting up your own mini manufacturing line — what’s the point? You’re going to want to inject some CNC code or something and have it carve you a sculpture! Or pour you a mixed drink I guess…
Maybe [Madeline] has the answer. Working as an artist in residence at Pier 9, she’s created wearable markers and a motion capture system that allows a giant ABB robot to see, and respond to your movements in a shared space.
Continue reading “Madeline Gannon The Robot Tamer!” →
