Upgrading DJI Flight Controllers
DJI, the company that gave us the far too popular Phantom line of quadcopters, doesn’t just make the most popular line of FPV quads. Their top of the line flight controller, The Naza V2, is very good, able to connect to flight planning software that will set waypoints, talk to peripherals over a CAN bus, and has improved flight algorithms. On the other hand, their ‘reduced price’ model, the Naza Light, can’t connect to these nifty CAN bus peripherals and has a bit of a problem with drifting the quad from one side or another.
The Naza V2 sells for around $300, and the Naza Light sells for about $170, both with a GPS module. The hardware inside the V2 and Light is exactly the same. We all know how this is going to go down, right?
[udnham] over on the RC Groups forum figured out a way to load the more capable Naza V2 firmware on the Naza Light, giving the cheaper flight controller features that were, until now, only found in the more expensive V2 hardware. The upgrades include better algorithms for GPS position and altitude hold, the ability to connect to DJI peripherals including the Bluetooth module, the iOSD, and camera gimbals, Octocopter support, the DJI datalink modem, and a bunch of other features.
Even though DJI is using the same hardware in the $170 Naza Light and the $300 Naza V2, upgrading the firmware requires an Internet connection to the DJI servers. [udnham] wrote a utility that modifies the /etc/hosts file on your computer, runs a service, and allows you to upgrade your firmware on the Naza Light. It’s basically a $130 firmware upgrade for a DJI flight controller that’s a single download away.
[udnham] set up a site where you can download the firmware flashing tool with a few videos showing the upgrade process and the improvement over the stock firmware. You can check those out below.
Continue reading “Upgrading DJI Flight Controllers”
