Now you can experience the excitement felt for centuries by ice fisherman thanks to this cellular-capable tip-up.
For the uninitiated a little ice fishing primer may be in order. The majority of what you see above is a standard tip-up rig for ice fishing. Basically it lets you set many baited lines and just watch for a flag to pop up when one of them hooks a fish. Just drill a hole in the ice and drop the line through — the orange frame rests on the surface of the ice.
The add-on here is the grey box which is hiding an Xbee device. A magnet and reed switch (which can be found at the local hardware store) complete a circuit when the flag is down. But if the flag pops up the reed switch opens (or closes, we’re not sure which) and the Xbee sends an alert to a base station, which then converts that to a text message to push to your phone. As you guessed, there’s a video after the break.
Fun and convoluted. But not entirely useless. We’d suggest swapping the Xbee/cellular hardware for a cheap microcontroller/Bluetooth setup. This way you can knock back a few cold ones in the ice house while waiting for the wireless network to alert you via an SL4A script.
Continue reading “The Excitement Of Ice Fishing Now From Anywhere In The World”
