The solar-electric tractor is out standing in its field.
Adding Solar Power To An Electric Tractor
In my country, we have a saying: the sun is a deadly lazer. Well, it’s not so much a folk saying as a meme, and not so much in one country as “the internet”. In any case, [LiamTronix] was feeling those cancer rays this harvest season when running his electric tractor, and realized that– since he’s already charging it with ground-mounted solar panels anyway–if he’s going to build a roof for his ride, he might as well make charge the batteries.
Another bonus is safety: the old Massey-Ferguson at the heart of the electric tractor build didn’t come with any rollover protection from the factory back in the 1960s. Since having however many tons of tractor roll onto you was bad enough before it got a big hefty battery pack, we heartily approve of including a roll cage in this build. Speaking of battery packs, he’s taking this chance to upgrade to a larger LiFePo pack from the LiIon pack he installed when we first featured this conversion in 2024.
Atop the new roll cage, and above the new battery, [Liam] installed four second-hand 225 W solar panels. Since that’s under 1kW even if the panels have not degraded, the tractor isn’t going to be getting much charge as it runs. In the northern winter, [Liam] is only able to pull 80 W from the set. That’s not getting much work done, but who wants a tractor without a cab or heater when it’s below freezing? In the summer it’s a much better story, and [Liam] estimates that the roof-mounted panels should provide all of the energy needed to run the tractor for the couple hours a day he expects to use it.
If you’re wondering how practical all this is, yes, it can farm  — we covered [Liam] putting the project through its paces in early 2025.
An Electric Converted Tractor CAN Farm!
Last October we showed you a video from [LiamTronix], in which he applied an electric conversion to a 1960s Massey-Ferguson 65 which had seen better days. It certainly seemed ready for light work around the farm, but it’s only now that we get his video showing the machine at work. This thing really can farm!
An MF 65 wasn’t the smallest of 1960s tractors, but by today’s standards it’s not a machine you would expect to see working a thousand acres of wheat. Instead it’s a typical size for a smaller operation, perhaps a mixed farm, a small livestock farm, or in this case a horticulture operation growing pumpkins. In these farms the tractor doesn’t often trail up and down a field for hours, instead it’s used for individual smaller tasks where its carrying or lifting capacity is needed, or for smaller implements. It’s in these applications that we see the electric 65 being tested, as well as some harder work such as hauling a trailer load of bales, or even harrowing a field.
In one sense the video isn’t a hack in itself, for that you need to look at the original build. But it’s important to see how a hack turned out in practice, and this relatively straightforward conversion with a DC motor has we think proven itself to be more than capable of small farm tasks. Its only flaw in the video is a 30 minute running time, something he says he’ll be working on by giving it a larger battery pack. We’d use it on the Hackaday ancestral acres, any time!
Continue reading “An Electric Converted Tractor CAN Farm!”
